Cannot seems to update the hub to the new platform update this morning.. it gets to 2% and then fails. Is there something going on with the ability to download or is it my hub?
Maybe try a reboot and try again.
I would take a backup first though. Just in case.
I've done that -- that is the first thing I do with any issue. Still -- will not go beyond 2%.
I’ve been doing a lot of testing with the newer versions on my primary hub and test hub lately (long time platform update hold out here) and have not had a problem.
I’d recommend a database backup, then soft reset. If you can then upgrade, restore your previous database.
Going to try to restore to the prev version after trying all other options. I can only work on this once every other day or so... I have also tried to so start up in safe mode and get an error 401. That is odd.
I am out of options -- I have even reset the Hub to no avail. I have not added a device in 3 months or any new rules. The Hub has been updating fine each time until this last update so I do not understand the issue at all - really disappointing. It does get to 50% now but that takes 20 minutes and then says Download Failed.
Thanks -- I do not know who that is but I have been reaching out to support also and have not heard back, yet.
Curiosity.. I have seen this a few times in the forums... But what is your internet source from your provider?.. DSL/Cable/Fiber/Wireless/LTE?
The reason I ask.. I could be a MTU issue
I have Cable from spectrum ultimate
Ill do some network tests and see what I get.
That was the issue -- thanks for leading me to that end. I was able to change the MTU settings and do a refresh on my router and that resolved the issue.
What did you change the MTU value from/to? I've got the same issue, cannot successfully download the latest update. Thanks
