New up date = no radios working
Since the new update no zigbee or zwave devices work. I have tried a older restore and z wave repair . nothing will work/ change state or report . I have a c5 and I am in Australia. Hub appears to work thru web browser, all devices are listed under zwave and zigbee, but cant be turned on etc they are just all inactive.Any Ideas? is it time to bin it??
First recommendation is usually to shutdown hub from the settings menu, remove power for a few minutes, and restart.
Have you check logs and hub events to see if there are any clues?
logs are
search
dev:2992022-06-28 09:29:07.977 am infoToilet light heated towel rail energyDuration is 167.72 Days
dev:2992022-06-28 09:29:07.970 am infoToilet light heated towel rail energy is 52.4kWh
dev:2002022-06-28 09:29:06.703 am debugparse:zw device: 0C, command: 5B03, payload: F7 02 02 , isMulticast: false
dev:3952022-06-28 09:29:05.127 am infomaster roller shutter is closing
dev:2992022-06-28 09:29:02.009 am infoToilet light heated towel rail power is 37.2W
dev:3632022-06-28 09:28:46.114 am infowalk in PIR: temperature is 21.7
dev:3632022-06-28 09:28:31.304 am infowalk in PIR: motion is inactive
dev:2002022-06-28 09:28:11.703 am debugparse:zw device: 0C, command: 5B03, payload: F6 02 02 , isMulticast: false
dev:3632022-06-28 09:27:49.815 am infowalk in PIR: motion is active
dev:3632022-06-28 09:27:32.400 am infowalk in PIR: illuminance is 7
dev:3962022-06-28 09:27:29.322 am infooutside lights energyDuration is 32.83 Days
dev:3962022-06-28 09:27:29.316 am infooutside lights energy is 0kWh
dev:3962022-06-28 09:27:23.287 am infooutside lights power is 0W
dev:2002022-06-28 09:27:16.702 am debugparse:zw device: 0C, command: 5B03, payload: F5 02 02 , isMulticast: false
dev:2992022-06-28 09:26:24.220 am infoToilet light heated towel rail energyDuration is 167.72 Days
dev:2992022-06-28 09:26:24.213 am infoToilet light heated towel rail energy is 52.4kWh
dev:2002022-06-28 09:26:21.701 am debugparse:zw device: 0C, command: 5B03, payload: F4 02 02 , isMulticast: false
dev:2992022-06-28 09:26:18.229 am infoToilet light heated towel rail power is 36.9W
dev:2042022-06-28 09:25:47.792 am infogenerator run Temperature Int : Temperature is 17.7°C
dev:2002022-06-28 09:25:47.767 am debugSensor Multilevel Report - Sensor Type: 1, Sensor Value: 17.7, Scale: 0
dev:2002022-06-28 09:25:47.711 am debugMultiChannel Encap Src: 7, Dst: 0, CC: 49, CMD: 5
dev:2002022-06-28 09:25:47.695 am debugparse:zw device: 0C, command: 600D, payload: 07 00 31 05 01 22 00 B1 , isMulticast: false
dev:3632022-06-28 09:25:44.398 am infowalk in PIR: temperature is 21.6
dev:2992022-06-28 09:25:32.296 am infoToilet light heated towel rail energyDuration is 167.72 Days
dev:2992022-06-28 09:25:32.289 am infoToilet light heated towel rail energy is 52.4kWh
dev:2002022-06-28 09:25:26.701 am debugparse:zw device: 0C, command: 5B03, payload: F3 02 02 , isMulticast: false
dev:2992022-06-28 09:25:26.295 am infoToilet light heated towel rail power is 36.7W
some devices have started working. master bedroom roller shutter does not . thermostat does not
logs for master shutter are
ev:3952022-06-28 09:36:36.150 am infomaster roller shutter is closing
dev:3952022-06-28 09:36:34.135 am infomaster roller shutter is opening
its a qubino shutter module . it updates status on device page but no output at device
the roller shutter is working now , I had two revert to its own driver that prevously didnt work. I have a qubino 1d relay that has never worked. it can be included but thats it. its mpn is zmnhnd2h1s4p2. I have tried it again but still no change???
Based on the details you shared, it doesn't sound like there is a hardware malfunction, but rather some troubles with your mesh. Surprisingly that both Zigbee and Z-Wave would be hit at the same time by misbehaving devices, but pretty sure that's what caused the problem. If you'd like us to check your engineering logs, please send me a private message with your Hub's ID.
