There is a comunity driver developed by @kkossev which you can find here.
The thing is that are so many versions to this Tuya device and no standards so basically each model might require a tweek to the driver. Even worse, many times you can not realy tell if the device you are buying is supported already or not until you add it to your hub and get the real manufacturer version.
I suggest you check with @kkossev and he might be able to explain further.
I am waiting for a version to support mine when @kkossev will have the time to do it.
So, you can
