Hi All
Have just seen this article on a new Tuya Zigbee thermostat, planning to order a bunch for UFH control to replace some dumb stats.
Does anyone know if there is an existing driver that would support these?
Hubitat C8
Mike
Hi All
Hubitat C8
Mike
There is a comunity driver developed by @kkossev which you can find here.
The thing is that are so many versions to this Tuya device and no standards so basically each model might require a tweek to the driver. Even worse, many times you can not realy tell if the device you are buying is supported already or not until you add it to your hub and get the real manufacturer version.
I suggest you check with @kkossev and he might be able to explain further.
I am waiting for a version to support mine when @kkossev will have the time to do it.
So, you can
