New Switch works from dash but not from automations
Did you refresh the page? Did you try hitting either Save or Configure again?
If it does, to me that indicates a switch that is defective, or the very slight possibility of a mesh issue.
I have never had a good switch change behavior on its own. On the other hand, I have had a lot of bad GE/Jasco over the years, and it wouldn't shock me to find out you had one as well.
Yeah I tried hitting refresh, I tried save and configure again, and it didn't really change. Now it still says "1 Pending Changes" I'm beginning to suspect the switch is bad, so I'm going to do the exclude, and then re-attach and if it keeps doing this I'll return it for a new switch. thank you for all the help.
Following up on this topic, and closing it down. I got a replacement switch from Amazon and that switch has been rock steady since I installed it about 2 weeks ago, so I assume the switch itself was bad.
