New Shelly Wave Pro Dimmer 2PM driver is not correct
Hi,
I just upgraded a C7 (so no ZWJS) to 2.4.1.253 to test out the newly added Shelly Wave Pro Dimmer 2PM driver, but it is not working as it should. I am using it for the EU version, but that should work exactly as the US version.
First all six child devices are created as dimmers. However, only child devices 1 & 2 are dimmers, the rest are switches SW1 - SW4.
In the parent device preferences the Switch Types are not correct. There are four input fields, but they duplicated for SW3 and SW4. They are missing for SW1 and SW2. Also a lot of the configuration parameters are not showing.
I must say the device itself is not ready for prime time either. Only the Switch Type 1 (momentary) is working, type 2 does nothing with the inputs, with type 3 both outputs respond to any connected switch. Shelly is aware and working on it.
Cheers Rene
Do you mean Shelly Pro Dimmer 2PM or Shelly Wave Pro Dimmer 2PM?
Sorry, the Wave (Z-wave) indeed. Corrected the title.
Hi,
Any change of this driver getting fixed?
