So been having fun with this, moving stuff across from ST bit by bit, sorting out snags as I go. All pretty good so far. I think I may have to keep the ST on in the lng run for various legacy reasons, but happy so far.
The main problem I've had is that I'm using HubConnect to link the ST to the HE, and HE can see the ST devices etc all fine and dandy, but I can't see any HE devices in ST? I've selected these in the HE app and have the ST app installed by I can't see an HE devices in ST, am I missing a step? I did a search on the forums and couldn't see anyone else with this issue so I must be doing something dumb!
I guess that is possible but I have never tried it. I control everything with HE. My ST hub basically just relays commands form my HE system to the few devices I have left on there.
I've made some real newbie clangers which means I've had to redo some things but can't say I regret it so far. You definitely need to make sure you do your research for some stuff, there's not really a single point of all info you need.
Part way through the journey now and all good. Well worth the effort.
Woke up this morning, nothing working, no response from hub so can’t look at logs or do anything,
Hub has green light on.
Can’t think what to do except cycle the power, so I pull the plug.
Hub reboots, goes from blue to green, but no change. Can’t access the hub, nothing works, and although it’s green I can’t see it on the network.
Any clues? I’ve seen a lot of stuff about safe reboots but can you do this without access the UI?
Thinking I may have to revert to ST as although this may be something daft I’ve done if you can’t get the system back that’s a problem, partly because I’m highly likely to do something draft again!
All other devices are ok and visible on the network, ST, Hue, Harmony. And even if it was a network issue stuff should still work?
So I've rebooted and moved to a different network connection and got it working, so it must have been the network I guess? A bit worrying that nothing works if it loses it's connection, that can't be right? I mean I guess Hue etc won't work, but I thought the other stuff (Zigbee etc) should work?
I could even see it on the network, so that was impossible.
Am I correct in thinking that except the network devices and interfaces, everything should keep working even if it loses the network connection? That's one of the things that attracted me to it over ST.
As long as the hub doesn't reboot while disconnected from the network - yes, it should all keep working.
If it reboots with no network connection then the time will be incorrect (there is no internal Real Time Clock, so it has to get the current time on every reboot), so anything relying on time will not work as expected. Which is reason 1 that you should have the hub on a UPS (if it is not already).
As mentioned, pulling the power without doing a graceful shutdown runs a high risk of corrupting the internal database. That is reason 2 to have the hub on a UPS (if it is not already).
It's a shame it doesn't have a 'reset' button for a graceful reboot. If you can't access the UI you're stuffed and can only pull the plug. For the price of a push-button that seems a bit short sighted.
If you lose contact with the hub after a reboot your router (or other DHCP source) may have assigned a new IP address. There is a Find Hubs function on the Portal.Hubitat.com page. I use the Fing app on my phone.
Absolutely true. All my servers, printers, etc have assigned addresses. I was just trying to give him the least amount of information to get back on track.
Yes, it has an IP assigned to it. It's back now after three reboots. Seems odd. What there is in the log is about network issues, but there isn't much there.
Thanks for the suggestions. I guess it's a combination of investigating what devices may have caused it to to hang and cross my fingers and hope!!!
