New Homebridge Plug-in via MakerAPI
The strange thing is that even if i keep the device in the default room a reboot still throws those errors. Only happens with new devices all my previous devices before the updates to homebridge and HE don't get deleted
Your homebridge cache is messed up, I can see that.
You have the following in the log:
[3/28/2021, 11:00:18 AM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Z-Wave Contact Sensor) stored in cache, remove device Sidewalk Contact sensor
The text in bold should either be "device" or "mode" or "alarmSystem" but in your case it is the device name. I am trying to see right now how we can get you out of that.
Ok, try the following:
  1. stop homebridge
  2. add the following entry to your homebridge configuration file in the section for the maker API plugin:
    "delete_cache_devices": true
  3. start homebridge and wait until it is booted up. This should remove all "bad" entires
  4. stop homebridge
  5. detete that new entry from your configuration file
  6. start homebridge and try it again
I hve the same invalid devices as @shawnx1 and a "delete_cache_devices": true didn't help me.
Okay gave it try same results. at least it's only 4 devices I can live with that and it only happens when rebooting Homebridge. Hopefully more people will try to add new devices to homebridge and see if they get this problem. I thinking I'll need to delete makerAPI to fix this ugh
Get this log after deleting the two folders and also doing the "delete_cache_devices": true*...
2021-03-28 23:55:05 - Initializing HAP-NodeJS v0.9.3...
2021-03-28 23:55:07 - Loaded plugin 'homebridge-hubitat-makerapi'
2021-03-28 23:55:07 - Homebridge Version: 2.7
2021-03-28 23:55:07 - Plugin Version: 0.4.13
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] Registering platform 'homebridge-hubitat-makerapi.Hubitat-MakerAPI'
2021-03-28 23:55:07 - Loading 1 platforms...
2021-03-28 23:55:07 - [Hubitat MakerAPI] Initializing Hubitat-MakerAPI platform...
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Button) stored in cache, remove device HomeKit SlÀck alla lampor
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Presence with Switch) stored in cache, remove device Ella hemma
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Component Switch) stored in cache, remove device Cave taklampa
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Fibaro Dimmer) stored in cache, remove device Entre nere utelampa
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Z-Wave Smart Switch) stored in cache, remove device Ellas Z-Wave-switch
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (GoGoGate 2 Child) stored in cache, remove device GoGoGate2 door 1
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (GoGoGate 2 Child) stored in cache, remove device GoGoGate2 door 2
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Pianolampa on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Kök fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee RGBW Bulb) stored in cache, remove device Vardagsrum fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Kök fönsterlampa 3 on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (IKEA Tradfri RGBW Light) stored in cache, remove device Loas fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Z-Wave Contact Sensor) stored in cache, remove device Entre nere ytterdörr
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Gillestuga fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Button) stored in cache, remove device HomeKit Tv lights
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Vardagsrum lampa 4 on BÀltevÀgen C5
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Netatmo Outdoor Module) stored in cache, remove device Netatmo ute
2021-03-28 23:55:07 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Gillestuga fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Netatmo Basestation) stored in cache, remove device Netatmo uppe
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee CT Bulb) stored in cache, remove device Ellas fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Presence with Switch) stored in cache, remove device Tommy hemma
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (IKEA Tradfri RGBW Light) stored in cache, remove device Sovrum fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee RGBW Bulb) stored in cache, remove device Vardagsrum fönsterlampa 3 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Button) stored in cache, remove device HomeKit SolnedgÄng
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (TELLDUS Mini modified Zooz) stored in cache, remove device TvÀttstugan garderobsbelysning
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Fibaro Dimmer) stored in cache, remove device Trapplampa
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Z-Wave Smart Switch) stored in cache, remove device Vardagsrum ljusslinga
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Netatmo Additional Module) stored in cache, remove device Netatmo nere
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Z-Wave Lock) stored in cache, remove device Entre nere Danalock
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee CT Bulb) stored in cache, remove device Idas - Fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee Bulb) stored in cache, remove device Kök fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Temperature Sensor) stored in cache, remove device Bastutemperaturen
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Button) stored in cache, remove device HomeKit Nattuggla
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (TELLDUS Mini modified Zooz) stored in cache, remove device Kök ljusslinga
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee CT Bulb) stored in cache, remove device Vardagsrum jordglob on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Advanced Zigbee RGBW Bulb) stored in cache, remove device Vardagsrum fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Zigbee - Generic Outlet (with Presence)) stored in cache, remove device Vardagsrum IKEA Harmony switch
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Virtual Presence with Switch) stored in cache, remove device Anna hemma
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Generic Zigbee Switch) stored in cache, remove device Garaget - poolbelysning
2021-03-28 23:55:08 - [3/28/2021, 3:55:07 PM] [Hubitat MakerAPI hhm:0.4.13] Fetching Hubitat-MakerAPI devices. This can take a while depending on the number of devices configured!
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Refreshing All Device Data
2021-03-28 23:55:08 - Preparing Advertiser for 'HE Homebridge AC56' using bonjour-hap backend!
2021-03-28 23:55:08 - Starting to advertise 'HE Homebridge AC56' using bonjour-hap backend!
2021-03-28 23:55:08 - Bridge is running on port 51826.
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Received All Device Data
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device HomeKit SlÀck alla lampor
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Ella hemma
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Cave taklampa
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Entre nere utelampa
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Ellas Z-Wave-switch
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device GoGoGate2 door 1
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device GoGoGate2 door 2
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Pianolampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Kök fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Kök fönsterlampa 3 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Loas fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Entre nere ytterdörr
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Gillestuga fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device HomeKit Tv lights
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum lampa 4 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Netatmo ute
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Gillestuga fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Netatmo uppe
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Ellas fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Tommy hemma
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Sovrum fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum fönsterlampa 3 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device HomeKit SolnedgÄng
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device TvÀttstugan garderobsbelysning
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Trapplampa
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum ljusslinga
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Netatmo nere
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Entre nere Danalock
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Idas - Fönsterlampa on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Kök fönsterlampa 2 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Bastutemperaturen
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device HomeKit Nattuggla
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Kök ljusslinga
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum jordglob on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum fönsterlampa 1 on BÀltevÀgen C5
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Vardagsrum IKEA Harmony switch
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Anna hemma
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Remove stale cache device Garaget - poolbelysning
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Starting receiver
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Set communcation_broken to false
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] Setting MakerAPI post URL to http://192.168.107.2:20010/event at http://192.168.107.4/apps/api/109
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] homebridge-hubitat-makerapi server listening on 20010
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] latest version on npmjs is 0.4.13
2021-03-28 23:55:08 - [3/28/2021, 3:55:08 PM] [Hubitat MakerAPI hhm:0.4.13] your version of the plugin is up2date
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Gillestuga fönsterlampa 1 on BÀltevÀgen C5, ID 1414
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Anna hemma, ID 200
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Ellas Z-Wave-switch, ID 1353
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Tommy hemma, ID 142
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Kök ljusslinga, ID 961
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name HomeKit SlÀck alla lampor, ID 257
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum ljusslinga, ID 1223
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name HomeKit Nattuggla, ID 259
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Cave taklampa, ID 577
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Entre nere Danalock, ID 66
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name GoGoGate2 door 2, ID 528
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum lampa 4 on BÀltevÀgen C5, ID 1409
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Garaget - poolbelysning, ID 1057
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Ellas fönsterlampa on BÀltevÀgen C5, ID 1404
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum fönsterlampa 1 on BÀltevÀgen C5, ID 1405
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Ella hemma, ID 201
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Loas fönsterlampa on BÀltevÀgen C5, ID 1402
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Bastutemperaturen, ID 1385
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum IKEA Harmony switch, ID 97
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Idas - Fönsterlampa on BÀltevÀgen C5, ID 1398
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name HomeKit SolnedgÄng, ID 34
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name HomeKit Tv lights, ID 258
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Kök fönsterlampa 2 on BÀltevÀgen C5, ID 1416
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum fönsterlampa 2 on BÀltevÀgen C5, ID 1407
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Trapplampa, ID 1354
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Netatmo ute, ID 1321
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Kök fönsterlampa 3 on BÀltevÀgen C5, ID 1401
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Entre nere ytterdörr, ID 1351
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name GoGoGate2 door 1, ID 527
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Kök fönsterlampa 1 on BÀltevÀgen C5, ID 1399
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Pianolampa on BÀltevÀgen C5, ID 1397
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Netatmo uppe, ID 1319
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum jordglob on BÀltevÀgen C5, ID 1408
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name TvÀttstugan garderobsbelysning, ID 1352
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Netatmo nere, ID 1320
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Gillestuga fönsterlampa 2 on BÀltevÀgen C5, ID 1415
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Sovrum fönsterlampa on BÀltevÀgen C5, ID 1403
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Entre nere utelampa, ID 1355
2021-03-28 23:55:10 - [3/28/2021, 3:55:09 PM] [Hubitat MakerAPI hhm:0.4.13] Device Added - Name Vardagsrum fönsterlampa 3 on BÀltevÀgen C5, ID 1406
2021-03-28 23:55:10 - [3/28/2021, 3:55:10 PM] [Hubitat MakerAPI hhm:0.4.13] MakerAPI postURL successfully activated
You switch over to a fresh c7 right? Did you have to install Makerapi or did you do the restore apps and settings thing?
I restored from a C5 backup.
would you be willing to delete makerApI and start over????? :crazy_face: It seems this is only happening with new devices
I will do that but not today. It's 00:06 am here and I need to go to bed. Kids will wake me in ~5 hours...
Ok, I can see in this log that every device was removed and then cleanly added. What happens with the next reboot?
Well I'll take what I can get :slight_smile: I'll probably give it a try myself but I have doubts it would fix this problem.
Just reinstalled from scratch, same problems with fresh Makerapi app. don't bother with removing makerApi.the problem is most likely not on our end something changed
Same problems fresh install of makerAPI & homebridge
[3/29/2021, 8:09:16 AM] [Hubitat MakerAPI hhm:0.4.13] Invalid Device Indentifier Type (Hue Motion Sensor) stored in cache, remove device Backyard Motion Sensor
all devices get this error homebridge ends up adding them back after restart it clears stale cache every restart
If someone else running this plugin can just share a new device with Homebridge then restart homebridge see if you get the same Invalid device that would help a lot thanks. time to see what's differences are with other homebridge apps :crazy_face:
I was just about to remove my MakerAPI and start over. Now I will wait and see if someone finds a solution.
I’m willing to do tests if someone have an idea they wanna have tested to solve this.
I ended up installing Homebridge Hubitat Tonesto7 if you don't want to wait working fine.
I’ve been very happy with this version and @dan.t support is excellent. I will try to figuring this issue out, as long as he is willing and/or don’t give up. :slight_smile:
very true, I've tried everything though, I even rolled back to Hombridge 1.25 with no success. Only thing i can think of is something changed in makerapi might be waiting a while.
Wish I had a spare hub that I could try 2.2.5 or earlier. I have spent the weekend setting up my new C7 and configuring my old C5 as a ZigBee light bulb hub. It was kind of a pain so don’t want to mess with anything major right now.
If I rolled back to 2.2.5 I’m sure my C7 would explode and die. :slight_smile:
lol, I thought about doing that but I already upgraded both my hubs one's zwave others for zigbee
I have 7 hubs. One of them is a C-7 that is running 2.2.6.
I can probably start a MakerAPI instance and add that to yet-another-Homebridge instance. I think this must be a common config though. Like @dan.t I've encountered the HomeKit DB implosion many times over the years I've been using Homebridge/HomeKit. I haven't seen it in a very long time however. My current connection to Homebridge is via HubConnect, but the behind-the-scenes of that interaction with the Homebridge NodeJS instance is highly similar. I upgraded that Hub to 2.2.6 and have yet to see any Homebridge/HomeKit wobbles.
Although I could build up a comparison test, I suspect the critical element not available to me is the Room Allocation already being in place. I can't start today and get devices added to rooms, in order that an upgrade would have the potential to kill it.
