New Device - Ecolink Garage Door Controller GCZW7-ECO
I just got this new Ecolink Garage Door Controller GCZW7-ECO installed, and I had hoped that the Generic Z-Wave Garage Door Opener driver would work with it. It's close! The Open and Close commands work, but the state of the device never transitions to open or closed, and just gets stuck on the opening or closing states. I'm hoping to use this with my Hubitat dashboard and Homekit, so that's not going to be good enough for me :slight_smile:
Is it possible to get the source code for the Generic Z-Wave Garage Door Opener driver so I have something to work from in coding my own Custom Driver?
The tilt sensor is what should be supplying the status.. it tells the GCZW7 and then the GCZW7 tells the hub. Are you sure the Tilt Sensor has been paired to the GCZW7?
I went digging around the internet for some example drivers for other Garage Door Openers and found what was going wrong. Turns out I just needed to refresh the device status after it had decided the door was properly closed. I've set up a Rule Machine rule to refresh it every minute, and the device is now reporting the correct status.
Because the status is now working, the dashboard and HomeKit both work as well!
I'd still like to develop a proper driver for it, as I'm having to set some parameters on it with the Basic Z-Wave Tool driver, like the relay time, and door open or door close timeouts.
The driver you are using is internal to Hubitat but there are alternatives where the source is in the Community.
It's Zooz specific but the Child App might provide some hints because the child Driver uses it..
Any head way on this?
Can you enable debug logging in the device/driver preferences and see what comes into Logs when you'd expect the open or closed events? It's possible the driver isn't parsing the information correctly (but hopefully something is still coming in, and in that case there is hope).
I do not have one of these to test, so that's the next best thing. :slight_smile:
As soon as I get it installed and setup at the new house.
Still looking for this? I have one of these openers - captured a debug log opening and closing.
Similar to OP I setup a timer to refresh after the door starts closing or opening, but would prefer something less cludgy.
The logs also show my timer refreshing the status at the end.
Can't seem to attach the logs to this reply though :slight_smile:
Yeah, I don't think any work has been done on this driver, so debug logs would be great!
A screenshot of logs is normally easiest to work with (though I don't like that they aren't searchable or accessible). If you can't upload screenshots, make sure to join the "owners" group, which will let you: Hub owners - Hubitat
