I've migrated to a Pro and WC is in the apps and all the pistons are listed but WC app won't open.
I've HPM repaired it.
From what I have read it's an uninstall and reinstall/reload the pistons?
Can I just change some Oauth keys or something like that?
Well, the hub bricked after about an hour.
Took a bit to get in as it reverted to its shipping IP. Wouldn't respond to MAC or 8081.
Find my hub always said it was there. Blue LED solid.
Did a cloud restore again and behold if WC was working.
The Dashboards also started to work and the Hub Details populated; first time around I had to fill all that in manually.
?? I don't believe that the hub ships with an assigned IP.
Glad you are up and running.
I wonder about its origin.
Looked new but had a name "Springfield House" and pulled the same DHCP of .120 when I finally go it talking again.
I had changed the name and everything seem to be back to when it arrived.
Curious as to where you purchased this hub?
Sounds like a returned hub. Was this purchased as "new"?
Must have been used by Homer Simpson.
It it had been Homer, there would be tooth marks on it, he tries to eat everything.
Seriously, @dnickel - def sounds like a used box, if you bought it new from a valid reseller you should contact HE to let them know about your experience and talk about getting a replacement.
Yes. Sealed new from AARtech.
Purchased from a very large supplier of IoT here in Canada; I've used them for years.
I did have to cut the factory clear seals on the box so it sure looked new.
