I replaced by C7 with C8.
C7 used to be Hubitat <--> Homebridge <--> Homekit
C8 I have set up with the new Hubitat <--> Homekit integration
At first I noticed that controlling my Z-Wave devices from HomeKit was VERY slow. 3-30 seconds.
I later tested out and noticed that it is also that slow controlling them from Hubitat UI directly.
I did use cloud migration to move all my Z-Wave and ZigBee devices over from C7.
any advise to speed up operations again? With my C7 it used to be instantaneous always < 1 second.
In addition to all of the above suggestions, could you please post a screenshot of your zwave details, with all your zwave devices?
Perhaps we may see an issue with one device, or perhaps a zwave ghost, or something else.
Is this problem limited to only Z-Wave? Is it possible you're dealing with a general hub problem and happen to be using mostly or exclusively Z-Wave devices and notice it there for that reason? Asking because in this case, there are other places you could look for culprits. I'd start by checking a few things in Logs, including app and device stats (for anything that seems oddly high) or logs themselves (e.g., if you have lots of error entries).
You could also rule out a fixable database problem by doing a soft reset and restore โ a safe process (as long as you follow the directions and don't do anything else, like reset your radios) that can help clean things up if this is the cause.
How long had your hub been up and running at the time this screenshot was taken? Even though the signal strength is high, the devices have a fairly high number of route changes.
