New C-8 unit, blue light
Out of the box C-8 unit, wireless setup and shows constant blue light. Suggestions?
Have you tried a network reset? Tried using Ethernet?
So you used an ethernet cable to do initial setup, and then you used that connection to also add your wifi settings, and then you shut down ethernet and unplugged the ethernet cable?
I don't see how you have a blue light if you were connected with ethernet (green light) and then Joined a wifi network and got " Successfully joined Your Wi-Fi SSID Name". You should still have the green light if wifi actually connected.
