New C-7 bricked (nope, just lost, now found) But still doing weird stuff [Resolved]
That's a good thought...
I've followed Bruce's 'how to make a strong mesh' doc pretty closely as I've added things to this new hub, slow and give it time to acclimate. I've had a bunch of failed/unreachables/etc which I attribute to the C-7 zwave "issue". Some of that issue likely/maybe explains the randomness?? The house is embarassingly sprawling, All these devices are in a 30'x50' two story box.
If you're willing to take a look.... here's the total of what's zwave on that HE unit... minus one scene activator (remotec ZRC-90) that's too far down the list.
Are those blinds plug in or battery operated? I don't know enough about them.
So if you ignore those for a minute, that leaves 14 or so repeating devices. That probably is OK depending upon how large your house is, and how well the signals are able to travel through your walls etc. From my observation on this and other forums, this is about the minimum amount of repeating devices to have a good mesh.
But if you have a larger house, or if these devices are quite spread out, then you probably should try a repeater or two. It can't hurt anything (except your wallet) to try. My opinion is that you probably should put one near the blinds at a minimum, and maybe another somewhere closer to the hub.
So my next question would be what brand/model are all those "generic zwave dimmers"? That driver implies that they are older Zwave not Zwave plus devices.
The blinds are plug-in... they are Bali, using Somfy z-wave tech.
the full "Z-wave seizure" happened again this morning, no idea when because the logs don't stretch back that far.... but this time all the blinds did eventually go up. First 1, then 2,3,4 all at once, a minute later 'closet'.... about 3 minutes after that the last 'dressing'. In case it triggers an idea I will say the blinds seem to respond with snap and precision when done from the device page one at a time, I suspect it's when the group fires that the proverbial hits the fan. To work that idea, after yesterdays 'spasm' I changed the blinds group to disable on/off optimization. That does seem to have helped (one day doesn't make a pattern).
And I'm not sure if it matters but I still have the mad-as-a-hatter C-4 live till I can get all those devices moved over (after I get this stable)... so it's likely spitting out all sorts of nonsense on the z-wave freq. I've no idea how much troubleshooting is going to be snookered by that unit messing with things.
Some of those generic dimmers are zooz Z+ gen2, I didn't realize that the driver would change the repeater function of the device. I assumed, since my use is basic... on/off/dim that it didn't matter. Am I wrong?
As always, appreciate the assit!
It won't change the repeater characteristics. But a device with a wrong or bad driver might be sending wrong commands to devices and cause issues.
I don't think that is the right driver for those Zooz, or any other non-plus switches/dimmers.
@bobbyD I'm getting this z-wave spasm regularly, 1-2 times a day (seems to depend on how many times I run the rule listed at the top)... Makes the new unit nearly useless and really frustrating for the family. I'm getting some pressure to go back to a square wheel...
I know y'all are working on it, but any ETA on the fix, or anything I do to help provide the info you need?
There is a fix that will be released in the next update. Unfortunately, I don't have a time-frame when the next update will be released.
Did you try switching the drivers for the Zooz?
I am quite sure you should be using the Zwave Centralscene dimmer driver. (see below chart) And you should check anything else that has the plain Zwave driver too. That is the wrong driver for Zwave plus devices.
https://docs.hubitat.com/index.php?title=List_of_Compatible_Devices
Also, could you please disable the polling for the time being to see if that alleviates your Z-Wave problems?
That chart doesn’t seem to be kept up to date. For example, it lists built-in drivers for the Aeotec Door/Window Sensor 7 and Aeotec Recessed Door Sensor 7 that haven’t been available for selection in quite a few months, when they became Deprecated in favor of the buggy consolidated Aeotec Door/Window 7 Series built-in driver. I’ve pointed this out to support in each of the bug reports I have filed in the past few months, but the table remains unchanged.
I will give you that.
But unless someone can show otherwise, the Zooz (or any other Zwave plus device), do not use the generic Zwave switch/dimmer drivers. They use the generic Zwave Centralscene or Zwave Smart drivers unless there is a device specific driver like your Aeotec example.
working on it,... seems I have to take off every cover plate to see if/what's behind. I'll get to that this week. Frankly I don't understand why if there's a driver for it, the generic is picked by the unit during the add.
@bobbyD are you talking about z-wave poller app or ?? I'm not using the poller app and the only polling I'm doing (that I can think of) is of IP based devices.
BTW, I did add a couple Aeotec Range Extender 6 repeaters. One is about 5' from hub (per something I read in another thread) and a second near the blinds area.... I've also (going against my instinct when having a problem) moved a few more Z+ devices in this part of the house from the C-4 to C-7.
Just to document in the hopes it helps. Here's the log from this AM Started live logging before doing the double tap and kept logging till zwave started it's spasm about 20s later. All this log is from one double tap.
dev:542020-10-06 07:37:02.290 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:37:01.928 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:37:01.898 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:37:01.836 am infoBedroom - blind - 3 is opening
dev:462020-10-06 07:37:01.790 am infoBedroom - Pyramid Lamp is off [digital]
dev:492020-10-06 07:37:01.638 am errorjava.lang.IllegalStateException: Queue full (on)
dev:542020-10-06 07:37:01.565 am errorjava.lang.IllegalStateException: Queue full (on)
dev:522020-10-06 07:37:01.533 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:37:01.452 am errorjava.lang.IllegalStateException: Queue full (on)
dev:522020-10-06 07:37:01.373 am errorjava.lang.IllegalStateException: Queue full (on)
dev:492020-10-06 07:37:01.364 am errorjava.lang.IllegalStateException: Queue full (on)
dev:542020-10-06 07:37:01.351 am infoBedroom - blind - dressing is opening
dev:512020-10-06 07:37:01.259 am errorjava.lang.IllegalStateException: Queue full (on)
dev:522020-10-06 07:37:01.233 am errorjava.lang.IllegalStateException: Queue full (on)
dev:542020-10-06 07:37:01.159 am errorjava.lang.IllegalStateException: Queue full (on)
dev:512020-10-06 07:37:00.954 am errorjava.lang.IllegalStateException: Queue full (on)
dev:512020-10-06 07:37:00.871 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:37:00.835 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:502020-10-06 07:37:00.829 am errorjava.lang.IllegalStateException: Queue full (on)
dev:232020-10-06 07:37:00.793 am infoBedroom - Cozy Sw was turned off
dev:462020-10-06 07:37:00.711 am errorjava.lang.IllegalStateException: Queue full (off)
dev:512020-10-06 07:37:00.705 am infoBedroom - blind - 3 is opening
dev:542020-10-06 07:37:00.651 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:37:00.597 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:37:00.580 am infoBedroom - blind - dressing is opening
dev:452020-10-06 07:37:00.541 am errorjava.lang.IllegalStateException: Queue full (off)
dev:462020-10-06 07:37:00.500 am infoBedroom - Pyramid Lamp is off [digital]
dev:522020-10-06 07:37:00.437 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:37:00.412 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:37:00.359 am errorjava.lang.IllegalStateException: Queue full (on)
dev:492020-10-06 07:37:00.248 am errorjava.lang.IllegalStateException: Queue full (on)
dev:482020-10-06 07:37:00.170 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:37:00.135 am infoBedroom - Cozy Sw was turned off
dev:522020-10-06 07:37:00.029 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:37:00.011 am infoBedroom - blind - 4 is opening
dev:482020-10-06 07:36:59.957 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:59.786 am infoBedroom - Cozy Sw was turned off
dev:462020-10-06 07:36:59.584 am errorjava.lang.IllegalStateException: Queue full (off)
dev:542020-10-06 07:36:59.525 am errorjava.lang.IllegalStateException: Queue full (on)
dev:462020-10-06 07:36:59.513 am errorjava.lang.IllegalStateException: Queue full (off)
dev:502020-10-06 07:36:59.460 am errorjava.lang.IllegalStateException: Queue full (on)
dev:452020-10-06 07:36:59.407 am errorjava.lang.IllegalStateException: Queue full (off)
dev:522020-10-06 07:36:59.393 am errorjava.lang.IllegalStateException: Queue full (on)
dev:452020-10-06 07:36:59.360 am errorjava.lang.IllegalStateException: Queue full (off)
dev:492020-10-06 07:36:59.325 am errorjava.lang.IllegalStateException: Queue full (on)
dev:442020-10-06 07:36:59.264 am errorjava.lang.IllegalStateException: Queue full (off)
dev:542020-10-06 07:36:59.241 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:36:59.100 am infoBedroom - Blind - 2 is opening
dev:522020-10-06 07:36:59.031 am infoBedroom - blind - 4 is opening
dev:502020-10-06 07:36:58.941 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:36:58.905 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:58.857 am errorjava.lang.IllegalStateException: Queue full (on)
dev:482020-10-06 07:36:58.850 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:502020-10-06 07:36:58.834 am errorjava.lang.IllegalStateException: Queue full (on)
dev:232020-10-06 07:36:58.783 am infoBedroom - Cozy Sw was turned off
dev:492020-10-06 07:36:58.757 am errorjava.lang.IllegalStateException: Queue full (on)
dev:502020-10-06 07:36:58.697 am errorjava.lang.IllegalStateException: Queue full (on)
dev:482020-10-06 07:36:58.542 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:522020-10-06 07:36:58.506 am infoBedroom - blind - 4 is opening
dev:232020-10-06 07:36:58.480 am infoBedroom - Cozy Sw was turned off
dev:502020-10-06 07:36:58.387 am infoBedroom - Blind - 2 is opening
dev:472020-10-06 07:36:58.306 am errorjava.lang.IllegalStateException: Queue full (off)
dev:522020-10-06 07:36:58.288 am errorjava.lang.IllegalStateException: Queue full (on)
dev:482020-10-06 07:36:58.213 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:462020-10-06 07:36:58.136 am infoBedroom - Pyramid Lamp is off [digital]
dev:502020-10-06 07:36:58.123 am infoBedroom - Blind - 2 is opening
dev:232020-10-06 07:36:58.106 am infoBedroom - Cozy Sw was turned off
dev:462020-10-06 07:36:58.098 am errorjava.lang.IllegalStateException: Queue full (off)
dev:462020-10-06 07:36:58.064 am infoBedroom - Pyramid Lamp is off [digital]
dev:462020-10-06 07:36:58.054 am infoBedroom - Pyramid Lamp is off [digital]
dev:472020-10-06 07:36:57.972 am debugparse() >> zwave.parse(zw device: 13, command: 2603, payload: 00 , isMulticast: false)
dev:472020-10-06 07:36:57.921 am debugparse() >> zwave.parse(zw device: 13, command: 2603, payload: 00 , isMulticast: false)
dev:442020-10-06 07:36:57.858 am errorjava.lang.IllegalStateException: Queue full (off)
dev:462020-10-06 07:36:57.831 am errorjava.lang.IllegalStateException: Queue full (off)
dev:522020-10-06 07:36:57.828 am infoBedroom - blind - 4 is opening
dev:492020-10-06 07:36:57.824 am errorjava.lang.IllegalStateException: Queue full (on)
dev:502020-10-06 07:36:57.816 am errorjava.lang.IllegalStateException: Queue full (on)
dev:542020-10-06 07:36:57.757 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:36:57.613 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:36:57.268 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:57.211 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:502020-10-06 07:36:57.199 am infoBedroom - Blind - 2 is opening
dev:232020-10-06 07:36:57.134 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:56.946 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:522020-10-06 07:36:56.921 am infoBedroom - blind - 4 is opening
dev:232020-10-06 07:36:56.869 am infoBedroom - Cozy Sw was turned off
dev:502020-10-06 07:36:56.467 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:36:56.334 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:36:56.234 am infoBedroom - Blind - 2 is opening
dev:512020-10-06 07:36:56.080 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:55.878 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:512020-10-06 07:36:55.849 am infoBedroom - blind - 3 is opening
dev:502020-10-06 07:36:55.795 am infoBedroom - Blind - 2 is opening
dev:232020-10-06 07:36:55.790 am infoBedroom - Cozy Sw was turned off
dev:502020-10-06 07:36:55.681 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:36:55.164 am infoBedroom - blind - dressing is opening
dev:542020-10-06 07:36:54.985 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:36:54.889 am infoBedroom - Blind - 2 is opening
dev:502020-10-06 07:36:54.792 am infoBedroom - Blind - 2 is opening
dev:482020-10-06 07:36:54.657 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:54.620 am infoBedroom - Cozy Sw was turned off
dev:502020-10-06 07:36:54.534 am infoBedroom - Blind - 2 is opening
dev:512020-10-06 07:36:54.445 am infoBedroom - blind - 3 is opening
dev:512020-10-06 07:36:54.411 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:54.324 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:54.296 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:54.237 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:53.689 am infoBedroom - blind - 3 is opening
dev:512020-10-06 07:36:53.686 am infoBedroom - blind - 3 is opening
dev:542020-10-06 07:36:53.668 am infoBedroom - blind - dressing is opening
dev:512020-10-06 07:36:53.604 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:53.528 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:53.404 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:53.266 am infoBedroom - blind - 3 is opening
dev:542020-10-06 07:36:53.093 am infoBedroom - blind - dressing is opening
dev:512020-10-06 07:36:52.842 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:52.727 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:512020-10-06 07:36:52.698 am infoBedroom - blind - 3 is opening
dev:232020-10-06 07:36:52.646 am infoBedroom - Cozy Sw was turned off
dev:522020-10-06 07:36:52.511 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:36:52.289 am infoBedroom - blind - dressing is opening
dev:512020-10-06 07:36:52.179 am infoBedroom - blind - 3 is opening
dev:502020-10-06 07:36:52.038 am infoBedroom - Blind - 2 is opening
dev:482020-10-06 07:36:52.020 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:522020-10-06 07:36:51.961 am infoBedroom - blind - 4 is opening
dev:232020-10-06 07:36:51.869 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:51.695 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:502020-10-06 07:36:51.645 am infoBedroom - Blind - 2 is opening
dev:232020-10-06 07:36:51.624 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:51.488 am infoBedroom - blind - dressing is opening
dev:542020-10-06 07:36:51.474 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:51.189 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:51.154 am infoBedroom - Cozy Sw was turned off
dev:502020-10-06 07:36:51.008 am infoBedroom - Blind - 2 is opening
dev:482020-10-06 07:36:50.975 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:50.949 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:50.912 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:50.772 am infoBedroom - blind - 3 is opening
dev:502020-10-06 07:36:50.757 am infoBedroom - Blind - 2 is opening
dev:522020-10-06 07:36:50.702 am infoBedroom - blind - 4 is opening
dev:512020-10-06 07:36:50.568 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:50.389 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:512020-10-06 07:36:50.368 am infoBedroom - blind - 3 is opening
dev:502020-10-06 07:36:50.362 am infoBedroom - Blind - 2 is opening
dev:232020-10-06 07:36:50.304 am infoBedroom - Cozy Sw was turned off
dev:522020-10-06 07:36:50.291 am infoBedroom - blind - 4 is opening
dev:512020-10-06 07:36:50.187 am infoBedroom - blind - 3 is opening
dev:522020-10-06 07:36:49.963 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:49.842 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:49.808 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:49.721 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:49.719 am infoBedroom - blind - 4 is opening
dev:512020-10-06 07:36:49.673 am infoBedroom - blind - 3 is opening
dev:522020-10-06 07:36:49.411 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:49.117 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:36:49.066 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:48.893 am infoBedroom - blind - 4 is opening
dev:502020-10-06 07:36:48.733 am infoBedroom - Blind - 2 is opening
dev:512020-10-06 07:36:48.683 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:48.377 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:48.290 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:48.046 am infoBedroom - blind - 3 is opening
dev:522020-10-06 07:36:48.031 am infoBedroom - blind - 4 is opening
dev:512020-10-06 07:36:47.836 am infoBedroom - blind - 3 is opening
dev:522020-10-06 07:36:47.708 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:47.617 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:46.970 am infoBedroom - blind - 4 is opening
dev:502020-10-06 07:36:46.947 am infoBedroom - Blind - 2 is opening
dev:522020-10-06 07:36:46.818 am infoBedroom - blind - 4 is opening
dev:502020-10-06 07:36:46.595 am infoBedroom - Blind - 2 is opening
dev:502020-10-06 07:36:46.388 am infoBedroom - Blind - 2 is opening
dev:512020-10-06 07:36:45.961 am infoBedroom - blind - 3 is opening
dev:522020-10-06 07:36:45.690 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:36:45.656 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:45.523 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:36:45.359 am infoBedroom - blind - dressing is opening
dev:502020-10-06 07:36:45.349 am infoBedroom - Blind - 2 is opening
dev:482020-10-06 07:36:45.283 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:45.224 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:45.145 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:44.970 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:44.962 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:44.878 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:44.813 am infoBedroom - blind - 3 is opening
dev:502020-10-06 07:36:44.787 am infoBedroom - Blind - 2 is opening
dev:542020-10-06 07:36:44.785 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:44.629 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:512020-10-06 07:36:44.613 am infoBedroom - blind - 3 is opening
dev:232020-10-06 07:36:44.518 am infoBedroom - Cozy Sw was turned off
dev:522020-10-06 07:36:44.279 am infoBedroom - blind - 4 is opening
dev:482020-10-06 07:36:44.239 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:44.222 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:44.163 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:44.038 am infoBedroom - blind - 3 is opening
dev:482020-10-06 07:36:43.994 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:43.961 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:43.949 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:43.778 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:43.743 am infoBedroom - Cozy Sw was turned off
dev:512020-10-06 07:36:43.713 am infoBedroom - blind - 3 is opening
dev:542020-10-06 07:36:43.657 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:43.495 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:43.458 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:43.421 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:43.396 am infoBedroom - blind - 4 is opening
dev:522020-10-06 07:36:43.264 am infoBedroom - blind - 4 is opening
dev:482020-10-06 07:36:43.171 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:43.128 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:43.102 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:43.065 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:42.901 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:42.813 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:42.746 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:42.722 am infoBedroom - blind - 4 is opening
dev:482020-10-06 07:36:42.650 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:42.604 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:42.477 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:42.410 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:42.345 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:42.231 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:42.189 am infoBedroom - blind - dressing is opening
dev:542020-10-06 07:36:42.185 am infoBedroom - blind - dressing is opening
dev:522020-10-06 07:36:42.175 am infoBedroom - blind - 4 is opening
dev:232020-10-06 07:36:42.158 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:41.892 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:462020-10-06 07:36:41.883 am infoBedroom - Pyramid Lamp is off [digital]
dev:442020-10-06 07:36:41.816 am infoBedroom - coffer was turned off [physical]
dev:442020-10-06 07:36:41.814 am infoBedroom - coffer was turned off [physical]
dev:232020-10-06 07:36:41.789 am infoBedroom - Cozy Sw was turned off
dev:522020-10-06 07:36:41.763 am infoBedroom - blind - 4 is opening
dev:542020-10-06 07:36:41.736 am infoBedroom - blind - dressing is opening
dev:462020-10-06 07:36:41.712 am infoBedroom - Pyramid Lamp was turned off [digital]
dev:482020-10-06 07:36:41.543 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:41.456 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:41.293 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:41.272 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:41.192 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:41.040 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:41.009 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:40.969 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:40.772 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:40.762 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:40.715 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:40.630 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:40.508 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:40.426 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:40.331 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:40.275 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:40.213 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:40.079 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:542020-10-06 07:36:40.070 am infoBedroom - blind - dressing is opening
dev:232020-10-06 07:36:40.027 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:39.890 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:39.829 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:39.756 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:39.740 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:39.617 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:39.556 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:39.502 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:39.400 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:39.362 am infoBedroom - Cozy Sw was turned off
dev:542020-10-06 07:36:39.319 am infoBedroom - blind - dressing is opening
dev:482020-10-06 07:36:39.266 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:39.240 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:39.170 am infoBedroom - Scene Controller button 5 was doubleTapped
dev:232020-10-06 07:36:39.130 am infoBedroom - Cozy Sw was turned off
dev:482020-10-06 07:36:39.067 am infoBedroom - Scene Controller button 5 was doubleTapped
--- Live Log Started, waiting for events ---
Wow. That's a lot of messages coming out of that device.
If you stop using/disable that device do things settle down.
Haven't read all the thread so apologies if you've already been there.
Resolved.
Two issues:
  • Button Controller App was "confused". Remove/re-add the app, reconfigure and that resolved much of the logging.
  • Blinds were using either the generic driver HE provides, or Z-Wvae shade community driver. Now using Somfy ZRTSI driver which is acting more reliably.
Marking this resolved. Thank you All.
I was going to say it looked like the button was being repeatedly tapped
