I can't get the ERIA Adurosmart Zigbee Dimmable warm white bulb to work with hubitat. It pairs but assigns it with the 'Nue Zigbee Dimmer' driver - and none of the commands work with this driver. I then tried each type of zigbee driver one after another (hitting save, then clicking configure) but none of them work. Any ideas what may be going wrong? Has anyone else managed to get this to pair correctly?
Some of my bulbs are the ERIA Adurosmart Zigbee RGBW bulbs, and I use the Advanced Zigbee RGBW Bulb driver. So, perhaps try the Advanced CT Bulb driver?? My suggestion would be to fully factory reset the bulb, re-pair, and (if necessary) change the driver as noted above. If I remember correctly, I ended up clicking configure a couple of times in the process to make sure the configuration "took."
