I'm using MS Edge Chromium with my own generated certificates. The certificate placed in /hub/advanced/certificate is the full chain in the following order (Hub Cert > Intermediate Cert > CA Cert).
This really sounds like a hardware malfunction. If you didn't do so already, please open a warranty case by visiting the following page:
I have not but I also don't see an option for this (unless I can use the same authorization code as last time):
One last thing to check - is there anything on the network that uses jumbo frames?
Also, are jumbo frames enabled on the router?
This is one thing that's known to freeze the hub. A replacement hub will not help in this case - it will freeze just the same.
I checked the switches along it's path and they had jumbo frames disabled however the UDM Pro had them enabled when it should not have. That is now disabled.
Ok, let's give it a couple of days. The hub will likely stop freezing now, but please let us know if still does.
Can this be addressed in the OS networking code?
I'm looking at it, but hot updating low level OS files on eMMC storage carries a non-trivial risk of messing up the OS into non-bootable state.
For sure. And the majority of home users don't use jumbo frames anyway.
Looks like we won't have to wait that long - Just checked it and it's not reachable.
Update:
I restarted both my UDM Pro and the hubitat this morning and am monitoring it to see how long it lasts. Current uptime is 3hrs.
Looks like the answer is about 1 day is the answer for that run. Woke up this morning and the hub was unreachable on the network.
Any ideas?
Yes, please check your email
