Nest 4th Generation Learning Thermostat
I just tried adding the 4th generation of Nest Thermostats. I've tried it in the past and it had successfully connected to the built-in Matter driver. However, it has recently been updated and now comes in as a Matter Bridge. This allows for any attached temperature sensor and the humidity data to be brought into Hubitat as well. Can the built-in driver be updated to capture this new endpoints? When I run get info from the device, I see the following:
dev:11025/22/2026 9:51:08.403 aminfofingerprint endpointId:"66", inClusters:"001D,0003,0402,0039,002F", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
dev:11025/22/2026 9:51:08.401 aminfofingerprint endpointId:"65", inClusters:"001D,0003,0402,0039,002F", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
dev:11025/22/2026 9:51:08.400 aminfofingerprint endpointId:"64", inClusters:"001D,0003", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
dev:11025/22/2026 9:51:08.398 aminfofingerprint endpointId:"03", inClusters:"001D,0003,0405", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
dev:11025/22/2026 9:51:08.396 aminfofingerprint endpointId:"02", inClusters:"001D,0003,0402", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
dev:11025/22/2026 9:51:08.394 aminfofingerprint endpointId:"01", inClusters:"001D,0003,0006,0201,0204", outClusters:"", model:"Nest Learning Thermostat 4th gen", manufacturer:"Google LLC", controllerType:"MAT"
The built-in generic matter bridge doesn't capture the thermostat, but does show the following fingerprints:
Endpoints found: [[endpointId:02, inClusters:001D,0003,0402], [endpointId:03, inClusters:001D,0003,0405], [endpointId:64, inClusters:001D,0003], [endpointId:65, inClusters:001D,0003,0402,0039,002F], [endpointId:66, inClusters:001D,0003,0402,0039,002F], [endpointId:65, label:Chloe Temperature Sensor, inClusters:001D,0003,0402,0039,002F], [endpointId:66, label:Logan Temperature Sensor, inClusters:001D,0003,0402,0039,002F]]
@bcopeland
