I easily included the subject smart plug but no buttons show up for on or off. On my phone it says it is unsupported. Is anyone at Hubitat addressing this problem. Is there a work around.
Go to the device info and change the type to the generic zwave outlet driver. Also my custom Zooz ZEN04 driver works on just about any zwave plug.
Also, if you want to run the "Get Info" command on the driver you're currently using (which must be the "Device" driver assigned when nothing else matches) and then provide the "fingerprint" entry you'll see get written to Logs when you do this, that can help a better driver get assigned automatically in the future.
Also, what hub platform version are you running? Check Settings > Hub Details. Unless you're intentionally on an older version, 2.4.0 should be better at this now, so I'm wondering.
