NEO NAS-AB02B2 Zigbee Siren (TS0601)
Hello. Does someone have success with running NEO NAS-AB02B2 Zigbee Siren (TS0601) ?
Have you tried if your device works with this driver?
If not, please provide the Zigbee model/manufacturer details.
I have had a Neo NAS-AB02B0 TS0601 for many years. While it works fine with Hubitat (in that Hubitat sees it and talks to it) via community drivers, the device itself is very flaky. It thinks it is connected to Hubitat but doesn't do anything sometimes. The sounds randomly stop working. Sometimes I have to power-cycle it to get it to work, other times re-initializing it via the UI is fine.
For now it works ok.
@RNoia Can you check whether you are using the latest driver version - it is v.1.3.4 dated 2025-02-22
What you describe was a problem in some early versions of the driver that should be fixed now.
