The child device seems to be platform agnostic, so it will probably just work.
The parent will need multiple edits to work on Hubitat. Check out the porting tips here...
Thanks for your help guys, decided to create virtual switches to control the two endpoints and this works perfectly, so by doing this the dual neo coolcam touch switch operates reallywell using the fibarro dual relay driver and virtual switches as the endpoints.
Hi Mike(@mike.maxwell)
Are there any plans to provide native HE support for Neo Coolcam switch? In the latest platform release you've already added couple of Neo Coolcam drivers.
Yes, I beleive it's in the works
Looks like it is supported starting in 2.0.3 update. Just a FYI since this was the one thing that was holding me back from completely converting over from ST (My whole house is full of these brilliant Z-Wave light switches (save cost and works great) from NEO Coolcam.
Anyone have pics of an installed single gang dual switch Neo Coolcam?
Thanks! That's a single gang? Looks wide.
UK version
At the risk of wrath from my wife for showing our dirty walls, here are some pics of the US version installed. Yes, dear, I'll be cleaning the walls... Couple of notes about installation. I think it's generally well designed. I have two quibbles.
One is that the screws stick out too far when a wire is in place. The screw heads don't have clearance to slide in past the mounting plate so you have to be pretty physical with it to go in.
Second is that the mounting plate causes it to stick out a bit. I could probably clear out some of the drywall so the mounting plate will go in farther, and I may do that at some point. As you can see, it leaves a gap if you don't do this. I'll probably fiddle with it some more to get it more flush to the wall.
No problems with it working in HE. Oddly, sometimes the touch on the panel takes a moment to activate the relay. It's enough of a delay that it's annoying because you're wondering if it registered the press. HE changes, including through Alexa, are immediate.
Wow, real shame about the gap !
I couldn't live with it like that. LOL
and those screw heads look lethal.
I had a similar thought about the screw heads, but take a look at any regular wall switch. The screw heads are exposed on those as well. Besides, I've been hit with 60hz. Probably won't be the last time!
I'm going to do something about the gap, just haven't figured out what yet.
Nah, not in Aus. ![]()
Anyone still tracking this or searched this thread, Neo Coolcam has released a 3 button version, but the buttons are REALLY CLOSE together.
Is there a driver for the Neo Coolcam 3 button version?
Hi Mike. Do you know if there is a Drive for the wallswitch 3 button version?
Not that I know of
This maight help with the gap for wall mounting
https://www.amazon.com/-/es/iMBAPrice-Non-Metallic-Shallow-Surface-Extender/dp/B085DQ8K5J/ref=pb_allspark_session_sims_desktop_60_3/147-3878111-8976753?_encoding=UTF8&pd_rd_i=B085DQ8K5J&pd_rd_r=6f9e6fea-7982-4f3b-a9d6-a4fc63ac0e6a&pd_rd_w=ESnUk&pd_rd_wg=DCMtV&pf_rd_p=e500004d-dce5-4973-9afd-bba519c83f08&pf_rd_r=BKV0QFEBKTZG9MSKJZY3&psc=1&refRID=BKV0QFEBKTZG9MSKJZY3
Thanks.
@mike.maxwell I am waiting for a Driver for Coolcam Light Switch with a 3 button version. Is theare any plans to have one in the near future? any.
Please I am waiting for a Driver. Thanks
Hi any news for 3ch driver. The one we can use as the Parent device, creates only 1 child device. So we are missing a 2nd child device, to work. Any good news?
