Need Recommendations For Ceiling Fan Remote Kits Compatible With BroadLink RM4 Pro
Good afternoon all,
Can anyone recommend what they are using as their aftermarket IR or RF ceiling fan remote kit(s) with their BroadLink RM4 Pro in HA?
Fans are very basic. A few pieces of information related to my environment:
  • I was using Home Depot Hampton Bay and Lowes Harbor Breeze remote control kits (see below). I believe they are pretty much the same and are remotes operating on 333.xx MHz but not completely sure of the exact frequency. After purchasing the BroadLink RM4 Pro hubs I have learned they do not work with them because they are not 315 or 433 MHz :anguished:
  • Fans are Home Depot Hampton Bay and Lowes Harbor Breeze.
  • I have 8 fans so I need to either be able to control 8 different fans as separate devices (preferred) or 5 fans as separate devices and a group of 3 as a separate device at one time (deck fans).
  • 3 Fan speeds. Low, Medium, High.
  • Single on / off light button
  • Current remote has a built in thermostat for controlling fan on / off by temp.
  • I learned from trying to use Bond controllers which provided a reverse option button the fans do support reverse [winter / summer / ] buttons so that would be nice to have on the remote. Reverse buttons nice but not a must have. The Bond controllers did not work out as I learned you could only have one within HA and the range wasn't working out.
I have looked for two days now and can't seem to find any recommendations (even from BroadLink) that would work. I think I am overthinking this one. I want to go with what is known to work by the community and not what the seller is saying will work and in all fairness they can't speak to the BroadLink RM4 Pro interoperability.
As always your guidance and expertise is always appreciated.
Thanks,
  • Don
Still working on the fans but did get this back from my inquiry to BroadLink support. Some may find it helpful for future reference.
..."Our universal remote supports IR/RF remotes and does not support Bluetooth/Wi-Fi remotes. The supported IR frequency is 38Khz, and the RF ranges are 305-335 MHz and 430~440 MHz. Please note that our remote does not support RF remote controls that use a long-press action or a rolling code...."
Based on the above I have a remote coming that I will be trying out and will update with the results.
  • Don
