vjv
August 2, 2018, 4:35pm
1
I have a contact sensor on my mailbox, when I tried to migrate it will show up as a device, changing the type to generic zwave contact sensor did not work. here is the info from ST:
zw:Ss type:0701 mfr:0109 prod:2001 model:0106 ver:5.01 zwv:4.05 lib:03 cc:5E,98 sec:72,5A,80,73,86,84,85,59,71,70,7A role:06 ff:8C07 ui:8C07
This is the contact sensor:
This Sensor mounts to a door or window, detects when it is opened or closed, and sends a Z-Wave® trigger signal to the network. It also has a tamper-proof switch, which will trigger a Z-Wave signal when the sensor's cap is removed. These trigger...
The same happened with another contact sensor but changing the device type solved the problem, here the device:
This Z-Wave Plus® Door/Window Sensor mounts to a door or window, detects when it is opened or closed, and sends a Z-Wave trigger signal to the network. It also has a tamper-proof switch, which will trigger a Z-Wave signal when the sensor's cover is...
I have 2 motions and I want to migrate them but not sure if they will work:
This passive infrared (PIR) sensor detects motion and sends a Z-Wave® trigger signal to the network. It also features temperature, humidity, and light sensors, which will automatically report changes in the conditions and will report the absolute...
Thanks, any help will be really appreciated.
They are on the compatible list so they should work. Have you tried pressing the configure then save and see if it's working? Also mesh issue maybe?
vjv
August 2, 2018, 8:41pm
3
For some reason, they are working now. HE configured the motions as Zooz 4 in 1, the options are confusing me, you can choose firmware based settings but my motions the firmware is 5.1 and this firmware is not there in the settings. Let see how they work...
vjv:
Because the driver is for a Zooz sensor and not Monoprice. They don't have the same firmware I think.
Rxich
August 24, 2019, 11:43pm
5
Hey VJV, curious just bought 3 monoprice z-wave door sensors(24259). I read that they don't check in unless door is opened/closed. How has your experience been? would you reccommend them or not?
TIA
vjv
August 25, 2019, 12:22am
6
I have one of those and it's been working fine for a year.
They report battery so the last activity will be open/close or battery.
