I'm sure this is easy to do but I've been trying to create a RM 4.0 rule to do the following:
Scenario - created a Virtual Switch that is used by IFTTT to turn on a robotic vacuum. That's easy enough and I set a timer to turn the switch off after 2 hours (based on battery life and time usually required to complete a clean). I have a second IFTTT rule that will send the vacuum home if the virtual switch is turned off while cleaning. In this scenario, I want the 2 hour timer to cancel. In my current try's the 2 hour timer doesn't reset and the vacuum will turn off after the original 2 hour timer.
That's what I need help doing? Any suggestions?
