Attempting to add a process delay using a runOnce as follows where contactDelay is 5000 milliseconds, but it wont work. Works without the delay coded.
log shows (note 1175 is the runOnce statement)
java.lang.IllegalArgumentException: Name cannot be null. on line 1175 (onContact1Event)
delayed contact event by 5000
There's a good chance I'm wrong but I don't believe you can pass parameters with runOnce that way.
It would have to be runOnce(date, processEvent [data:[deviceType, deviceState1, etc]]) or similar.
The SmartThings documentation only mentions overwrite: as a valid option in the map and data: is not listed. lists [data: ...] as a valid option key. Presumably, Hubitat should allow it to be used as well.
If a data: map cannot be passed on, since runOnce is executed independently, the only way I can think of to pass arguments is to use state objects, or a single state object to store a map of all of those arguments you are trying to pass.
Hmmm..I just dug up one of my old posts and I have this, that I remember working at the time. See snippet below. I believe the same should work for all the run's
Executes the handlerMethod once at the specified date and time.
Signature:
void runOnce(dateTime, handlerMethod [, options])
Parameters:
dateTime - When to execute the handlerMethod . Can be either a Date object or an ISO-8601 date string. For example, new Date() + 1 would run at the current time tomorrow, and "2017-07-04T12:00:00.000Z" would run at noon GMT on July 4th, 2017.
handlerMethod - The method to execute at the specified dateTime . This can be a reference to the method, or the method name as a string.
options(optional) - A map of parameters, with the following keys supported:
Key
Possible values
Description
overwrite
true or false
Specify [overwrite: false] to not overwrite any existing pending schedule handler for the given method (the default behavior is to overwrite the pending schedule). Specifying [overwrite: false] can lead to multiple different schedules for the same handler method, so be sure your handler method can handle this.
data
A map of data
A map of data that will be passed to the handler method.
