Hello I’m using motion and mode lighting with Sengled zigbee bulbs. I’ll post a SC of my rules. I’ll also post a SC of the log . Basically it looks like the light is going one percent to 100. As you can see I have different modes day, evening,night and home when we arm the alarm. So what’s happening is the hub is in day mode but the bulbs aren’t going to 100% as they should. They will stay at 25% because that’s the rule for home mode. So just to clarify if I set the alarm, the hub will then go into home mode, that puts that light at 25% when it’s in home mode. Once I disarm the alarm, it puts the hub in day mode, which then should make the lights go to 100%. However that’s not happening. They stay at 25% until I manually put them at 100 then after that the light stay at 100. The same thing will happen with a third reality Zigbee bulb in my bathroom. I’ll post logs and screenshots. Any idea what’s going on here?
And I have no idea why it’s going to 1% .
Then with the bathroom as the hub is in day mode the log should say the bathroom fan light was set 100%. However the log simply says turned on . Even know my the rule it says 100%
OK, here’s another example. I manually set bedroom hallway to 50%. I then turned the lights off manually by the app. After that, I activated the motion sensor, which should then put the light at 100%
The first SC is when I manually said it to 50%
The second screenshot is when I activated the motion sensor, which should’ve activated the rule to put it at 100% but it did not
The third screenshot is showing the level at 50
. However it did not do that. It kept them at 50%
