You might want to try the stock Generic Zwave Contact Sensor driver time see if it works. This way you are staying out of the box. You can always tag @mike.maxwell with the fingerprint to add to the driver.
They didn't work with the stock driver. I tried it with 2 different sensors a couple dozen times. I wouldn't even use them but they have external contacts that I needed for this application.
When you switched did you click configure?
Yep. Followed the same procedures as I did with the ported DTH (plus pulling batteries, tamper switch, etc. when it wouldn't work). I even tried rebooting the hub on several occasions. I tried device resets, excluding using ST, excluding using HE, excluding using a minmote. They just don't seem to like the HE stock universal driver for some reason.
@Royski Thank you for this driver code. I had the same issue as @oldcomputerwiz and this solved the issue for me. Much appreciated.
Woo hoo! I just purchased the same Everspring SM103 to use as a wired contact sensor to an infrared beam sensor to remind me if I've parked my car in the garage. This driver did the trick!
Came here because i couldnt get my mates first contact sensor (Everspring contact sensor i gave him) set up in his new Hubitat C7......and what do you know my good friend Roy's done it again, problem solved...lol
Thanks Again Roy.
hope your doing well, ive a night of porting an entire house over to HE from ST
Nice one matey long time no speak. Hope you had fun
This also worked for me, thanks so much!
