I got Echo Speaks up and running very nicely. Thank you @tonesto7!
But I need a little help getting it to work with Rule Machine:
I need a little help getting Echo Speaks working with Rule Machine
Several questions:
Can I get a command sent to an Echo group? I have a group called “Home” with all my Echos. Echo-Home shows up as one of my Echo Speaks devices, but the only command I get to work with that group is setVolume().
For individual Echos, how do I get them to play a specific radio station? I created a custom command called searchTuneIn('BBC World Service UK'). This command runs fine when I manually run it on any of my Echos. But it doesn’t work when I use it as a custom command in Rule Machine.
Similar playFlashBrief() plays my flash briefing perfectly when I test it manually. But it doesn’t work through Rule Machine.
My Rule Machine rules are below:
The commands that work are:
setVolume(50)
Speak on Echo
setVolume(30)
Command: searchAmazonMusic('Swing Jazz')
The commands that don't work are:
playFlashBrief()
It would be super helpful to have a screenshot of a working rule. I'll post one as soon as I have one...
I've found "Set Mode or Variables, Run Custom Action"
I choose "Run Custom Action"
then it wants me to "Set capability of Action Device". What should this be? None of the options in the drop down seem to apply.
Have you had any luck with multi-room "WHA" devices? This works on single devices, but my multi-room devices don't play anything even though they're discovered by Echo Speaks.
