Just a heads up. For many users, these older GE Z-Wave (non Plus) do not report their physical status changes back to Hubitat reliably, if at all. So, you may have an issue if the device is turned on manually at the switch itself, as Rule Machine will not be triggered. The newer Z-Wave-Plus devices behave much, much better.
As luck would have it, TheSmartestHouse currently has a sale on Zooz gear. I have a few of their Zen21 switches and Zen22 dimmers. They're z-wave+, have been super-reliable and are supported by native Hubitat drivers. The drivers also support their use as button controllers.
I use a very similar rule with my Closet light. It comes on at 99% (100% really) during Home and Away mode, and 20% in Sleep mode. I only have 3 modes.
This rule worked poorly with the GE z-wave dimmer I had earlier. It has never failed with the Zooz Zen22.
