Ok, I need some help. I'm probably missing something stupid... But I just can't see what.
Have a driver I'm working on, and need to set some parameters via preferences, or a command button. Neither way is working, so I thought I would show my simpler of the two - the command button I'm using for troubleshooting.
Any thoughts?
def ChangeDuration(){
log.info "ChangeDuration"
def cmds = []
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 22, parameterNumber: 8, size: 2)
cmds << zwave.configurationV1.configurationGet(parameterNumber: 8)
log.info "Cmds: " + cmds
delayBetween(cmds, 1000)
// This does not work----> delayBetween(cmds, 1000)
// This works----> zwave.configurationV1.configurationSet(scaledConfigurationValue: 99, parameterNumber: 8, size: 2).format()
The delayBetween command runs fine, well at least no errors. But as you can see from the log below (top line is result from basic zwave tool), it doesn't actually set the value... It was 99, and should have been set to 22... But it is clearly still 99.
The command line value is size 2, so that makes extra brackets in the cmds list (as seen in the log printout of the cmds list below), but I wouldn't think that would break it (?).
LOGS:
dev:3912019-01-23 07:46:44.428 pm infoConfigurationReport- parameterNumber:8, size:2, value:99
dev:3912019-01-23 07:46:32.360 pm infoCmds: [ConfigurationSet(configurationValue:[0, 22], defaultValue:false, parameterNumber:8, scaledConfigurationValue:22, reserved11:0, size:2), ConfigurationGet(parameterNumber:8)]
