it did not truggerHi all i need help with a simple timer
Please explain what you are trying to do.
You have no trigger, rule will never start unless started from another rule.
Perhaps you should explain what it is you are trying to do. It looks like you want a simple timer.
Trigger : Certain time 5:00PM
Action
Turn on tree
wait for event certain time 9:00PM
turn off tree
I am trying to tun lights on at 5 pm an off at 9 pm
but uf it on before 5 go off at 9pm
Ok. Then the rule @terminal3 gave above does exactly what you want.
Edit: while the above rule from @terminal3 does work, you might find it more understandable, for something simple like this, to use a Basic Rule, rather than the full power (and complexity) of Rule Machine:
