I just ordered 3 of THESE Sengled Smart Bulb. When I try to join them to the Hubitat hub via Zigbee, they are just found as "device". I have tried several different drivers (Generic Zigbee RGBW bulb, Advanced Zigbee RGBW, Sengled LED Element Color Plus)...not of these drivers work.
When I say they don't work, I change the driver...hit "Save Device", then hit "Configure" and I can't control the bulb from the page (i.e. on/off, color, temperature, etc.) Here is the device details:
These are newer firmware, hence not picking the correct driver, but they work with both the advanced and the color plus drivers.
If they aren't working you may need a router between the hub and the bulbs...
I am curious what firmware these are? there is another post from the other day with the same issues. Sengled E21-N1EA RGB zigbee bulb
I just received two of these bulbs on Saturday and was able to use the Sengled Element Colour Plus driver. My newly received bulbs are * firmwareMT: 1160-80CC-00000024
OK - I was able to get it to work with the Sengled Element Color Plus driver.
I had to wait for the bulb to blink a few times (I guess finish the pairing process)...then I was able to change the driver and hit config to make this work.
