I have been following the instructions from Greg Hesp. My novice skills got me to the point of downloading the credentials json file.
Next instruction was to execute the command "npm run start". The command starts but then fails. I am not experienced enough to resolve the error messages. Perhaps someone can advise me steps to resolve. Here is what the npm run start command yields:
pi@raspberrypi:~ $ cd Assistant-Relay
pi@raspberrypi:~/Assistant-Relay $ npm run start
assistant-relay@3.3.2 start /home/pi/Assistant-Relay
pm2 start ./bin/www && pm2 log www
[PM2] Applying action restartProcessId on app [www](ids: [ 0 ])
[PM2] www ✓
[PM2] Process successfully started
│ id │ name │ mode │ ↺ │ status │ cpu │ memory │
│ 0 │ www │ fork │ 31 │ online │ 0% │ 18.6mb │
[TAILING] Tailing last 15 lines for [www] process (change the value with --lines option)
/home/pi/.pm2/logs/www-out.log last 15 lines:
0|www | GET /static/css/2.4af953f8.chunk.css 200 3.366 ms - 268376
0|www | GET /static/js/main.4e10c66e.chunk.js 200 14.154 ms - 62860
0|www | GET /static/js/2.2f2d0ed6.chunk.js 200 13.332 ms - 1765170
0|www | POST /server/userCount 200 83.082 ms - 10
0|www | GET /favicon-32x32.png 200 2.438 ms - 1435
0|www | GET /favicon-32x32.png 304 3.149 ms - -
0|www | GET /setup 200 8.665 ms - 3197
0|www | GET /static/js/main.4e10c66e.chunk.js 200 3.582 ms - 62860
0|www | GET /static/css/2.4af953f8.chunk.css 200 3.145 ms - 268376
0|www | GET /static/js/2.2f2d0ed6.chunk.js 200 2.734 ms - 1765170
0|www | POST /server/userCount 200 36.717 ms - 10
0|www | GET /favicon-32x32.png 200 2.523 ms - 1435
0|www | POST /server/addUser 200 35.757 ms - 297
0|www | POST /server/processOAuth 200 372.595 ms - -
0|www | POST /server/userCount 200 28.743 ms - 10
/home/pi/.pm2/logs/www-error.log last 15 lines:
0|www | at require (internal/modules/cjs/helpers.js:77:18)
0|www | at Object. (/home/pi/Assistant-Relay/helpers/server.js:5:17)
0|www | at Module._compile (internal/modules/cjs/loader.js:1133:30)
0|www | at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
0|www | at Module.load (internal/modules/cjs/loader.js:977:32)
0|www | at Function.Module._load (internal/modules/cjs/loader.js:877:14)
0|www | at Module.require (internal/modules/cjs/loader.js:1019:19)
0|www | at Module.Hook._require.Module.require (/home/pi/Assistant-Relay/node_modules/require-in-the-middle/index.js:80:39) {
0|www | code: 'MODULE_NOT_FOUND',
0|www | requireStack: [
0|www | '/home/pi/Assistant-Relay/helpers/server.js',
0|www | '/home/pi/Assistant-Relay/app.js',
0|www | '/home/pi/Assistant-Relay/bin/www'
0|www | ]
0|www | }
0|www | Error: Cannot find module 'bonjour'
0|www | Require stack:
0|www | - /home/pi/Assistant-Relay/helpers/server.js
0|www | - /home/pi/Assistant-Relay/app.js
0|www | - /home/pi/Assistant-Relay/bin/www
0|www | at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
0|www | at Module.Hook._require.Module.require (/home/pi/Assistant-Relay/node_modules/require-in-the-middle/index.js:61:29)
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
0|www | ]
0|www | }
