Ok, tried it now. Removed the device and re-added, found as YOUPOU Multi Sensor.
Current States
- Driver Version Status : Up to date
- Illuminance : Null
Log:
dev:3882021-07-14 08:39:10.967 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:39:02.898 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:54.838 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:47.911 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:47.711 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:43.512 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020810D02000, dni:F806, endpoint:01, cluster:E002, size:08, attrId:D010, encoding:20, command:0A, value:00, clusterInt:57346, attrInt:53264]
dev:3882021-07-14 08:38:43.395 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E002080FD03002, dni:F806, endpoint:01, cluster:E002, size:08, attrId:D00F, encoding:30, command:0A, value:02, clusterInt:57346, attrInt:53263]
dev:3882021-07-14 08:38:43.279 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020806D03002, dni:F806, endpoint:01, cluster:E002, size:08, attrId:D006, encoding:30, command:0A, value:02, clusterInt:57346, attrInt:53254]
dev:3882021-07-14 08:38:43.174 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020A0ED0291400, dni:F806, endpoint:01, cluster:E002, size:0A, attrId:D00E, encoding:29, command:0A, value:0014, clusterInt:57346, attrInt:53262]
dev:3882021-07-14 08:38:43.044 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020A0DD0295A00, dni:F806, endpoint:01, cluster:E002, size:0A, attrId:D00D, encoding:29, command:0A, value:005A, clusterInt:57346, attrInt:53261]
dev:3882021-07-14 08:38:42.929 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020A0BD0290A00, dni:F806, endpoint:01, cluster:E002, size:0A, attrId:D00B, encoding:29, command:0A, value:000A, clusterInt:57346, attrInt:53259]
dev:3882021-07-14 08:38:42.796 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:F80601E0020A0AD0292800, dni:F806, endpoint:01, cluster:E002, size:0A, attrId:D00A, encoding:29, command:0A, value:0028, clusterInt:57346, attrInt:53258]
dev:3882021-07-14 08:38:42.741 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:40.601 traceSovrumstemp - Device alive/awake
dev:3882021-07-14 08:38:39.718 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:30.649 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:22.658 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:15.523 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:38:06.464 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:37:58.389 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:37:50.337 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:37:42.264 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:37:10.008 traceSovrumstemp - Luminance is nulllx
dev:3882021-07-14 08:35:49.538 debugSovrumstemp - Unhandled cluster. E002 is Unknown Manufacturer Specific Cluster, descMap = [raw:catchall: 0104 E002 01 01 0040 00 F806 00 00 0000 0B 01 0682, profileId:0104, clusterId:E002, clusterInt:57346, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:F806, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[06, 82]]
dev:3882021-07-14 08:35:49.454 traceSovrumstemp - Luminance is nulllx
Thanks for putting in the effort!
