Need confirmation on Homeseer dimmers/switches
Lots of options on how to dim them. :slight_smile:
I believe the most common are by time of day, and by mode (day/night/away). I do a number of dimming rules based on normal and middle of night - I don't want lights coming on full blast in them middle of the night if I have to get up, for instance.
Another basic question. I can see that I can set a double tap trigger for the switch in RM. The switch also supports triple tap and I was wondering if there is any way to set a triple tap trigger? FWIW the switch is a WD100+.
Just a quick update - the hum with the WD100+ is gone. I don't know if the switch somehow adjusts to the lights because the buzz is there briefly when the lights first turn on.
Or, maybe I got lucky with the switch / led bulb combo. It turns out it is actually quieter than the GE and Leviton dimmers with these bulbs.
