Need a switch for my infrared heaters
OP, sorry for the thread revive and off topic, but was curious as to what relays/contactors Denny is using for this setup?
We are in the process of building our new home and I'm looking at integrating a pair of the dual element heaters in our covered deck. While variable control would be nice, I'm not sure I have the budget currently for an elaborate SSR system. My tentative plan was something like Denny had mentioned, a single smart switch to 'turn on' the system and then individual switches for each heater to toggle either one or both elements.
Thanks in advance!
I'm afraid I don't know the relay models. I didn't do the original design, the electrician that built the house did. He had laid out the individual half height switches for the individual elements, and was planning to use an single gang electronic timer for the master on/off. I changed the timer to be a Z-Wave switch and run the timer on the Hubitat.
Bummer! I'm scheduled to talk with our electrician soon, was just trying to do a little homework ahead of time. Hopefully they have some ideas on how we can accomplish this.
Thanks!
Just wanted to provide an update for those looking at the same setup. We ended up having our electrical contractor wire us an additional 120v switch that will be used to trigger a contactor that will effectively turn on/off the individual controls for the heaters. For now, I'm going to use the cheaper INF regulators that Infratech sells to provide some adjustability for the heating elements.
Looking forward to enjoying some heat on our deck when this is all said and done!
I have 6 4000W Single element infratech heaters about to be installed and was thinking I could attach them to 6 of the aeotec heavy duty smart switches (installed in the basement).
Wanted to ask you all for your experience before I splash $700 on the switches!
Alternatively, maybe I buy 3 of the Sinope units (50A) and double up the heaters on each (less control, less money).
Thoughts? Especially from those of you have done it already!
You could buy 6 contactors (20a with 24vac coil), 1x 24vac power supply and 2x zen16 relay.
Quite a bit of wiring but you'd essentially plug your hot wires into the contactors and load from contactors to your heaters.
The zen16 relays (3 switches on each) would provide 24vac to the contactors to activate the coil and turn on the heaters.
Total cost would be like 200$ + a large electrical box. You'd only have two zwave devices to manage.
