I occasionally get a switch/dimmer that doesn't turn off when told to and some that do not accurately report their on/off status. I want to track the frequency of this over several weeks to determine if it's a device, brand, or location (mesh) issue.
I'm kind of a newbie so I don't know if this is something that can be done in Rule Machine or is more of a custom app. I would run this rule/app at a few minutes after another rule turns off a bunch of lights. If any are still on, It would trigger a notification(s) which devices are still on or reporting they're still on. Is this doable with a rule?
Thanks for your response.
This looks like it would turn off a switch multiple times to make sure it is off- that will likely solve my problem. Thank you. But what I really want to learn is which of my switches are misbehaving.
As @rlithgow1 notes, check your Z-Wave Details page and if you have any devices that don't show info in the Route column, post screen shots your Z-Wave Details page.
Also, what app are you using for the automation that is failing, and are you turning off a lot of switches at the same time?
Search on Device Status Announcer and Device Status Watchdog, they may have what you want.
But you should first ID if you have any ghosts, they can cause the behavior you're seeing.
If you don't have any ghosts adding some metering to your automations to slow down a flurry of commands being sent can help.
