Anyone seeing API errors? I noticed my garage door has not worked properly the last couple of days. When looking I see I'm getting an API error in the logs.
Things are working fine for me. I'm in the US and using the MyQ Lite application (3.1). What application are you using and what error are you getting?
Try controlling it with the Phone App to eliminate a problem with your login and/or device synchronization and the MyQ tilt sensor is working properly..
What driver / App sets are you using? I loaded the one from the bottom Friday and it works great. I use the "myq-garage-door-opener-nosensor.groovy" driver. Below are the messages I see in reverse chronological order. These are NORMAL messages.
- app:27852019-12-16 07:59:07.293 am debugGot response: STATUS: 204
- app:27852019-12-16 07:59:06.931 am debuggot accountid zzzzzzzzzzzzz
- app:27852019-12-16 07:59:06.930 am debugGot result: 0
- app:27852019-12-16 07:59:06.929 am debugGot response: STATUS: 200
- app:27852019-12-16 07:59:06.649 am debugGot LOGIN POST response: STATUS: 200 DATA: [SecurityToken:zzzzzzzzzzzzzzzzzzzzzzzzzzzzz]
- app:27852019-12-16 07:59:06.306 am warnToken has expired. Logging in again.
dcmeglio/hubitat-myq
Integrate SmartThings with MyQ. Contribute to dcmeglio/hubitat-myq development by creating an account on GitHub.
I'm using Myq lite as well. Just see the api errors in the logs. I'm not home right now to get the exact error.
I will try this when I get home. Didn't think to try the native app but unless someone changed my stuff should be good on that front. I will check to be sure.
Looks like it is offline. Thanks guys I just assumed the API changed since the last time this happened that was the root cause,
Copied the code from github, but got an error in the metadata statement while saving it in hubitat. The error message is: “ Metadata Error: Capability 'towertalent27877.lastActivity' not found. on line 21.” Anybody know how to fix it? Thanks.
