Looks like MyQ is broken again. Home Assistant looking for an owner of their code for MyQ. Anyone working on this? I'm studying not, but I think Chamberlain wants payment to access the API. Vehicles have this now. Maybe we should approach them and pay for access. Other approach is to ditch them.
Ditch the cloud service. Very easy to setup a local solution.
There's a whole thread of people who decided that around $50 is a bargain price to ditch MyQ and become completely local.
"This is the way."
Zooz zen 16 or 17 for z-wave or an MHCozy for zigbee, Ecolink tilt sensor (and if you have a yellow button on your garage door motor) a security 2.0 to dry contact sensor. Total cost, about 40 bux and will run in parallel with your OEM controls so you don't have to remove them. 100% local. Why do people keep putting up with the MyQ bs?
Another alternative is to use Home Assistant and pass it back to Hubitat via HADB. Their integration is more actively managed. Living in an urban area I do zero automation of the garage door, so outages don't really bug me much. If outages did make a difference to me I would go the Zooz + sensor route.
For myself it's more of being able to close the garage door vs opening it. I don't write rules to open because if something weird happens when I'm away I'd be exposed to theft
That would be my use case as well. All the newer MyQ have programmable auto shut within the hardware, so I use that. No need to make things more complex.
I just don't like the cloud aspect.... I had a my q and ditched it. And constantly fightinig them over the API... well that's just ridiculous...
All newer Chamberlain openers include MyQ. But there is no requirement to use it. Nor is there any internet connection for the hardware auto close functionality.
Right, but I still wouldn't use my q in general.
If I cared about integrating I wouldn't rely on it either. As a stand alone control it works well.
HA is experiencing the same issue.
They all experience the issue. HA is fixed already. Speed of fix was the point of my post.
Hmmm… I’ve applied the “fix” and it worked for a few days and then stopped again.
Fixed October 12
I think this is just Chamberlain/Liftmaster trying to monetize the API. They charge for access to control your doors from your car depending on OEM. Seems like they should publish a spec and allow access for a price. I am not sure what my next step is yet.
There's no mystery - that's all it is and they say so.
Either go the relay + sensor route for reliability or rely on developers to maintain their reverse engineered integrations.
Thanks for posting this! I had to remove the “fix” first but it’s working now.
Which fix did you remove?
