My seemingly never ending quest for a universal AV remote
I don't even know where to start here, I've been looking for universal remotes to use with my various AV setups for 20 some odd years now.
To be fair, my AV setups (8 of them currently) range from a simple TV to a full 9.2.4 Dolby Atmos theater.
The first remote being the original Philips Pronto, an ugly fiddley geekster oriented, yet capable IR only device that I used for several years, until well, its demise...
The second on the list was a Nevo S70 which I purchased from an installer who also gave me the configuration software, I spend months writing code for this thing, only to find out that the only reason I was able to get this device in the first place was that it was already end of life, I think that remote was like 6 or 7 hundred bucks...
Then I went the Harmony route, first with IR, then the hub based products, I probably had 5 of these at one point, while they worked, their lack of IP support or any other realistic local third party support and the seemingly lack of them being able to do exactly what I wanted eventually got the lot of them binned...
Third was what seemed to be the perfect remote which started and ended with a kickstarter project, the NEEO. I picked up two Black Cats for $450, they took forever to fulfill and whilst a little buggy here and there they did work for some of my more complex setups. And by far the best looking hardware to date. Well the end of that came when that company sold to Control 4, and that was the end of that story. C4 did maintain the device cloud configuration library for several years, until recently, and now they are bricks to me, I think they can be rooted, but I don't have the time for that.
The two of these are for sale if anyone is interested.
For the Atmos theater I built I needed something else, so I went the pro route and settled on RTI. I needed to become a dealer to even get near this stuff and eventually picked up an XP-3 training kit, which at the time was like a grand...
I had very high hopes for this and have probably spent weeks programming this thing, but could never get it to properly control an nvidia shield. I tried several different ways of getting the nav to work via various ADB and IP addons, it was always glitchy and slow, my last go to was using an FLIRC and IR, but no matter what the XP-3 just wouldn't send understandable commands over IR, epic failure.
I was able to hack in some code to get some button presses out of this thing to control the lighting in the theater, this did and continues to work well.
Also the XP-3 controller would occasionally lock up and require a reboot, same for the remote itself. IP control of the AV10 AVP sucked, so I switched over to IR, but long press volume was non existent, or when it did work just blasted and blasted, stupid thing. Maybe I could have fixed this with endless dinking with control repeats, whatever.
In the end the most reliable control of nvidia shields (and other android tv variants) is over bluetooth, which the XP-3 doesn't support...
So that theater currently has the big â– â– â–  RTI remote running everything but nvidia navigation and the nvidia remote running navigation...
So i was in search of another solution specifically for the theater...
I've been looking at sofabaton for a while as the brand keeps popping up here and there, but I was specifically wanting a remote that could pair to the shield via bluetooth, then see if there were any hooks into Hubitat that I could leverage for the theater lighting (and there are).
Well it turns out that the sofabaton XS1 could possibly fit the bill.
So I pulled the trigger one a few days ago and within 30 minutes had all the previous activities working over IR as well as having the device pair with the shield and working as well as the factory remote for navigation.
So next on to getting commands into Hubitat...
I don't have the need to command activities from Hubitat (though this is supposedly possible via their cloud API), i just need to be able to map some buttons on the remote to Hubitat events.
So in the sofabaton configuration app at the very bottom of the Wi-Fi add device section there is a very undocumented "Create a virtual device for IP control" link.
Creating a device and commands from this one is able to send events to Hubitat's LAN listener port of 39501.
There are all sorts of bugs in this interface, such as, it says the supported URL format is http:xxxx..., when it's actually http://xxxx as one would expect.
If you're thinking of doing a post without a route at the end of the request, it won't work.
and adding properly formatted JSON to the body is an epic failure, but just putting in simple text in the body works just fine.
I didn't try the other methods that are supported (route paths and query parameters), as the body text is good enough for what I need.
So in the end this remote is going to fit the bill, the hardware isn't as nice as the NEEOS, but I'm over it, I just need something that works and isn't loaded with buttons (who uses numbers on remotes anymore anyway?)
I haven't finished the driver yet, but I'm getting all the data I need to finish one out.
And this remote was less than 200 bucks...
For those that have made this far, basic driver posted:
I have three of the X1 remotes, unfortunatley they do not have the "Create a virtual device for IP control" option on the add wifi devices page. I've been using them with some tasmota IR controllers to get button presses into hubitat. It works well. The only issues I have had with my remotes is with the scroll wheel. I've had to replace two of the remotes already and another one is starting to have problems now too. Hopefully they have fixed this on the new X1S remotes.
Just the other day I was just looking at my old collection of Prontos and thinking that I might have had a bit of problem, but now I'm feeling much better. Thanks! :smile:
I have the original SofaBaton U1 and while it works, the emitter is not great and it eats batteries way too fast because of an oversensitive motion sensor. But I think I only paid around $40 for it so I'm not complaining.
I have peeked at the X1S and I'm happy to read that you've had some success with it. Also very interested in a HE driver but I would want to be sending commands to the X1S to control various devices via IR and it sounds like you're looking in the opposite direction. Still, what good is a hobby without challenges and that tax refund should be hitting the bank any day now.
I'm jealous! Mine is only 5.2.2 but will be 5.4.2 soon.
I'm following your adventure but I am very happy with my Hubitat dashboard. It controls AppleTV (thru Home Assistant), and the A/V Receiver and projector using a Broadband RM3. I would however prefer a remote with actual buttons vs touch screen. I tried to go with an air keyboard/mouse using an HA integration but it was a fail. HA "heard" most of the key presses on keyboard side but less than half on the A/V side for both devices I tried. The keyboard/mouse does work well on Nvidia Shield in Living Room. it's great when you want to enter terms in Search field to have a keyboard.
Given this is very much DIY, your solutions may vary depending on need I will likely post this to our GitHub example repo with example implementations posted in the driver code.
As far as LAN drivers go they don't get much simpler...
I don't know if music is your bag or not, but Tidal has some awesome Atmos content, particularly the Talking Heads Atmos remixes...
Also I wired this theater for 9.6.2, but ended up with 9.4.2 as I elected to use two channels out of the 15 amp channels available to run tactile transducers in the seating which are directly supported in the AV10.
Based on my research there was more bang for the buck in 9.4.2 vs 7.6.2 which I could have done with available amp channels.
Actually I have this backwards, should be 9.2.4 (9 base channels, 2 subs, and 4 Atmos ceiling speakers)
Thanks for tip but my setup is almost exclusively for the movies.
If you haven't already, put some LEDs around the screen with WLED that is sound-reactive and then get Hyperion if you want to go DIY route to control the LEDs to react to picture on screen. Now I will stop diverting your thread.
I’ve been using the Harmony puck for years now, along with their small remote. This has and continues to work for me, but I can’t make any configuration changes as my account login doesn’t work anymore (Should probably call them to get this fixed… if they will still answer…)
In my use case, the IR signal needs to go to the basement where all my equipment resides, except the TV which is in the Family room. The Harmony puck works extremely well for this, but a solution that shoots IR from the remote wouldn't.
What I would love to see is a small remote that has a few options on it (activities , direction arrows, enter, volume, off at a minimum) and where all of those commands can be intercepted by Hubitat to locally control everything.
Key to this is something that everyone can use with no training. And this is the case for the Harmony setup that I have, but when it stops working, I will want something else…
Wonder if the XS1 would work for this… will have to check it out!
Really pumped to hear this.
I still have a (mostly) working harmony remote but also decided to try out the SofaBaton X1S recently.
I’m pretty happy with it for my home theater control, and having a local integration point with Hubitat would be icing on the cake.
ETA: Oh and I am also jealous. Just 7.2.4 here :face_with_open_eyes_and_hand_over_mouth:.
example X1S driver code:
Just found that the X1S has a hub and IR blasters… So it may just fit the bill! And it looks to be on sale… or is $199 really the « normal » price…?
Does it charge via USB-C?
Yes, and it has two blaster ports.
ships with two blasters, one single headed and the other double
I got mine on Amazon for 169, but that sale seems over now
$169 is even better! I’ll keep an eye for the next sale to pull the trigger! :blush:
Just realizing that this is USD… so $199 is about $285 CAD… and it’s cheaper than that on Amazon.ca… so pulling the trigger!
Works good.
Thanks Mike!
I currently have the Harmony Elite with hub and I suppose a fairly basic setup controlling Denon AVR, TV, Apple TV and Virgin Media TV360/TiVo. Hoping this Sofabaton could replace that so I’m no longer worrying about the discontinued Harmony breaking (or the servers going offline). I’m using the Harmony integration in Hubitat to shut down the AV when I leave home or Goodnight and turn it on in a Good Morning routine. Would the X1S be able to do that? In the UK it’s just under £200 on Amazon and there’s an additional 5% discount currently. One question- is the hub itself an IR emitter (like the Harmony) or would I have to use the additional blasters?
Mike indicated above that it has two blaster ports, so that should work. That is why I ended up purchasing it.
I also wonder however to what extent Hubitat knows its state, and if the hub can send it commands… That is one thing that I really do like with the Harmony hub.
It's only going to know what you tell it using that driver. You can easily tell it to use one or more of the commands within each activity and the off command to teach what it's doing like the Harmony did, but that driver implementation can't control anything on the remote...
Ok, that’s good to know. Too bad it’s only one way though… that is one thing that is good with the Harmony. I can tell what “mode” it’s in, but I can also change it. So if everyone has left the room, but the entertainment system is still on, I can turn it off remotely.
Looking forward to trying it out!
I did 7.2.2, and wish I would have done 4 atmos/height channels.
Sofabaton... I bought 2 in their kickstarter run, and never received them. I went back and forth with the company about getting the units, until they ghosted me. So I never got to try them.
Honestly, what do you guys get above 5.1? Do you get additional narration from the director? :wink:
