No reply necessary. It is almost self aware.
You're not doing something right, then.
I'm curious, how many devices?
The hub that displays the dashboard, has the most devices, virtual included, shows 449.
Yikes! That's serious. I'm impressed.
You obviously haven't used my driver's... ![]()
What type of hub?
My main C-7 has 451 devices, including those brought in via Hub Mesh (which includes devices from an HA instance). It also works incredibly well.
C8Pro
My old C5 from 2020 is also working quite well with 266 devices and 373 apps. Have considered upgrading but I'm afraid to change what works.
The (sleazy) salesman in me would say "don't see it as a replacement but an addition to your already excellent setup..."
But seriously, you can add a newer hub to your setup without needing to immediately move everything across, hub mesh and other tools make things a lot more convenient than you might expect.
