I just looked at my Hub events log. I can see my HE system startup happens a few time a day. Is this normal?
I don't have any issues, but curious if this is expected.
I would suspect that this is not normal
My hub only shows startups when I purposely reboot (usually after an update)
Do you have the hub on a UPS?
If not, I would suspect external forces.. like a bad power supply or more likely power spikes
Does the reboot happen at regular times or does it seem random?
Andy
Here are examples. Seems it has been doing this since I first installed it.
latest from log........
systemStart | System startup with build: 2.0.1.117 | 2.0.1.117 | 2018-12-07 04:18:38.337 AM HKT | |
systemStart | System startup with build: 2.0.1.117 | 2.0.1.117 | 2018-12-04 05:11:59.832 PM HKT | |
systemStart | System startup with build: 2.0.1.117 | 2.0.1.117 | 2018-12-04 04:18:43.955 AM HKT | |
systemStart | System startup with build: 2.0.1.117 | 2.0.1.117 | 2018-12-03 11:05:55.993 AM HKT |
from start of logs.........
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-24 08:18:04.068 AM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-24 04:18:21.510 AM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-23 01:31:41.944 PM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-23 10:37:59.028 AM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-23 09:52:07.657 AM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-22 03:28:32.163 PM HKT | |
systemStart | System startup with build: 1.1.3.114 | 1.1.3.114 | 2018-08-22 02:53:53.883 PM HKT | |
syste |
I power my hub via a central 12vdc power supply can. It goes to a converter modual that outputs 5.5 vdc @ 15w. Like a usb pwr supply. Doing it this way I can remote reset pwr to HE if need be via an output relay.
Itβs definitely not normal compared to my two hubs. Mine only restarts when I tell it to via firmware upgrade or manually. I would reach out to support for guidance.
I just replaced the pwr supply with the HE original. I will watch it for a few days.
I suspect now that the supply I used @ 1.5A was at the threshold HE uses. I noticed the HE pwr is rated at 2A.
