My habitat was offline for a month
i had some internet issues at home and the device was offline for around a month.
now i try to set everything back.
i have some aqara water sensors and all of them are not connecting back.
what is the best way to reconnect them ?
Do not delete the device.
Go into zigbee device discovery.
Put the zigbee device into discovery mode.
The device should now be discovered as an existing device.
:crossed_fingers:
entered zigbee paring in HA "add device )
and enter the aqara paring mode. but the habitat does not recognize anything
If reset and pairing mode on those Aquara devices is separate, try resetting them to see if it makes a difference.
Are you able to pair other devices on the hub? Have you checked to ensure that your Zigbee radio is on?
You could also try rebooting the hub, just in case there is an issue with the radio - sometimes, it can make a difference. Best option is to turn it off and unplug it for several seconds.
zwave works like charm (most of them are fibaro)
i tried the reboot it did not help
worked after another try
