No worries. I took it a little further and added virtual switches to use for artists or genre, but I use webCoRE to perform the search, so control all I want from three different dashboard (for each Alexa device).
I copied the layout json for each then changed the Alexa device where needed. Works really well. I suspect you can do the same with Rule machine perhaps. The virtual switches I set as variables and use the search Spotify command, and pass the virtual switch name in the command.
So tapping on that just fires Echo Speak to get Spotify to play that? And that part all done via Webcore? Think could post screen shot of you piston for me to try and replicate that?
i am curious to the people who were doing this with the album art, artist, etc., how quick was the dashboard updating? When I tried, the tile wouldn't update until 30 seconds or more into the song so it seemed pointless. I am using Echo Speaks thru HubConnect.
Fortunately, I found a way to do it Node Red where the album art, song title, and artist are updated immediately when song starts.
Hi, I used the add in "Echo Speaks". It will add each of your echo's as a device. You can then use the music player tile to stop/start and control the volume and use the media source tile for additional information. The application is slick and can do all sorts of things with the echo. My specific issue is that I can't seem to get the Tune in search to work within the echo speaks actions app. If you decide to load up Echo Speaks, I would love to know if you or anyone else has the same issue. Have fun!
I hope some of the original posters are still active on this post, I just found it through googling.
My Spotify runs off of a Windows 10 machine housed inside an arcade cabinet, and is controlled primarily thru a 4:3 touchscreen, but is there a way I could link this to a Spotify tile like I'm seeing in this post?
So effectively I want to swap out the echo for a windows 10 pc.
Is this possible? Feasible?
Another thought, alexa can now run on a Windows pc... so could alexa be incorporated into said pc, which then is linked to Spotify
Completely read this thread - Summary: Anything you can say to an Echo can be made an automation with a virtual device. It is detailed, but very doable. I would give this a shot, Spotify is smart enough to see your account playing music on another device, so the Win10 PC should reflect what is being played (I think...) Good Luck
