I have many Aeotec Multisensor 6s. On the dashboard I can choose Temperature or Illuminance and it will display just that value and the sensor name in a tile. But If I select Humidity is also shows the battery % in the top left which causes an issue where space is limited. I don't want battery level there anyway as most of mine are USB powered and I have a separate dashboard page for battery levels only.
If I choose to just display the humidity as an attribute, it looses the % from the humidity level so it isn't clear what it is.
@patrick
Could the battery level be removed from the Humidity tile (or made an option if others need it)?
