Multiple subscriptions after migration
I had subscriptions on both my hubs, then migrated from C7 to C8 pro. I didn't know I could transfer subscriptions and the migration changed the name of my C8. Now, I see cancel pending on old hub subscriptions and the old name of my C8 on active subscriptions without remote admin (was subscribed to on C7). For now, I only want my C8 subscribed to hub protect and remote admin going forward.
Thanks!
Conrad
@bobbyD should be able to help straighten things out w/your subscriptions.
BTW, if you're going to run your C7 and C8 at the same time after the migration you're going to want to set you Zigbee channels on your C8 & C7 so they aren't on the same channel. C8 will typically be best on Zigbee channel 25 or 15, and C7 should be fine on 20. Those channels typically help keep your Zigbee channels away from your home's 2.4 HGz Wi-Fi signals.
Thanks for the C7 tip. I'll check with @bobbyD when I'm back in town on Jan 12.
Happy New Year!
