09:22:18 CMD: setoption43
09:22:18 SRC: WebConsole from 192.168.1.133
09:22:18 CMD: Group 0, Index 43, Command "SETOPTION", Data ""
09:22:18 RSL: tasmota/stat/RESULT = {"SetOption43":0}
09:22:24 WIF: Checking connection...
09:22:26 TYA: Send "55aa00000000ff"
09:22:26 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:22:26 TYA: Heartbeat
09:22:31 CMD: setoption54
09:22:31 SRC: WebConsole from 192.168.1.133
09:22:31 CMD: Group 0, Index 54, Command "SETOPTION", Data ""
09:22:31 RSL: tasmota/stat/RESULT = {"SetOption54":"OFF"}
09:22:37 TYA: Send "55aa00000000ff"
09:22:37 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:22:37 TYA: Heartbeat
09:22:44 WIF: Checking connection...
09:22:48 TYA: Send "55aa00000000ff"
09:22:48 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:22:48 TYA: Heartbeat
09:22:52 CMD: setsetoption69
09:22:52 SRC: WebConsole from 192.168.1.133
09:22:52 CMD: Group 0, Index 69, Command "SETSETOPTION", Data ""
09:22:52 RSL: tasmota/stat/RESULT = {"Command":"Unknown"}
09:22:59 TYA: Send "55aa00000000ff"
09:22:59 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:22:59 TYA: Heartbeat
09:23:04 WIF: Checking connection...
09:23:07 CMD: dimrange 10,255
09:23:07 SRC: WebConsole from 192.168.1.133
09:23:07 CMD: Group 0, Index 1, Command "DIMRANGE", Data "10,255"
09:23:07 RSL: tasmota/stat/RESULT = {"Command":"Unknown"}
09:23:10 TYA: Send "55aa00000000ff"
09:23:10 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:23:10 TYA: Heartbeat
09:23:21 TYA: Send "55aa00000000ff"
09:23:21 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:23:21 TYA: Heartbeat
09:23:24 WIF: Checking connection...
09:23:30 CMD: dimmer 50
09:23:30 SRC: WebConsole from 192.168.1.133
09:23:30 CMD: Group 0, Index 1, Command "DIMMER", Data "50"
09:23:30 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:23:30","Uptime":"2T20:31:47","UptimeSec":246707,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"POWER":"ON","Dimmer":50,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-48,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:23:30 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":50}
09:23:30 TYA: Send dim value=40 (id=3)
09:23:30 TYA: Send "55aa0006000803020004000000283e"
09:23:30 {"TuyaReceived":{"Data":"55AA0007000803020004000000283F","Cmnd":7,"CmndData":"0302000400000028","DpType2Id3":40,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000028"}}}
09:23:30 TYA: fnId=21 is set for dpId=3
09:23:30 TYA: RX Dim State=40
09:23:30 CFG: Saved to flash at F9, Count 585, Bytes 4096
09:23:32 TYA: Send "55aa00000000ff"
09:23:32 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:23:32 TYA: Heartbeat
09:23:37 CMD: dimmer 65
09:23:37 SRC: WebConsole from 192.168.1.133
09:23:37 CMD: Group 0, Index 1, Command "DIMMER", Data "65"
09:23:37 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:23:37","Uptime":"2T20:31:54","UptimeSec":246714,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"POWER":"ON","Dimmer":65,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-48,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:23:37 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":65}
09:23:37 TYA: Send dim value=79 (id=3)
09:23:37 TYA: Send "55aa00060008030200040000004f65"
09:23:37 {"TuyaReceived":{"Data":"55AA00070008030200040000005067","Cmnd":7,"CmndData":"0302000400000050","DpType2Id3":80,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000050"}}}
09:23:37 TYA: fnId=21 is set for dpId=3
09:23:37 TYA: RX Dim State=80
09:23:38 CFG: Saved to flash at F8, Count 586, Bytes 4096
09:23:43 TYA: Send "55aa00000000ff"
09:23:43 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:23:43 TYA: Heartbeat
09:23:45 WIF: Checking connection...
09:23:54 TYA: Send "55aa00000000ff"
09:23:54 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:23:54 TYA: Heartbeat
09:24:05 WIF: Checking connection...
09:24:05 TYA: Send "55aa00000000ff"
09:24:05 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:24:05 TYA: Heartbeat
09:24:16 TYA: Send "55aa00000000ff"
09:24:16 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:24:16 TYA: Heartbeat
09:24:25 WIF: Checking connection...
09:24:27 TYA: Send "55aa00000000ff"
09:24:27 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:24:27 TYA: Heartbeat
09:24:38 TYA: Send "55aa00000000ff"
09:24:38 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:24:38 TYA: Heartbeat
09:24:45 WIF: Checking connection...
09:24:49 TYA: Send "55aa00000000ff"
09:24:49 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:24:49 TYA: Heartbeat
09:25:00 TYA: Send "55aa00000000ff"
09:25:00 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:00 TYA: Heartbeat
09:25:05 WIF: Checking connection...
09:25:11 TYA: Send "55aa00000000ff"
09:25:11 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:11 TYA: Heartbeat
09:25:22 TYA: Send "55aa00000000ff"
09:25:22 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:22 TYA: Heartbeat
09:25:25 WIF: Checking connection...
09:25:33 TYA: Send "55aa00000000ff"
09:25:33 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:33 TYA: Heartbeat
09:25:44 TYA: Send "55aa00000000ff"
09:25:44 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:44 TYA: Heartbeat
09:25:45 WIF: Checking connection...
09:25:55 TYA: Send "55aa00000000ff"
09:25:55 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:25:55 TYA: Heartbeat
09:26:05 WIF: Checking connection...
09:26:06 TYA: Send "55aa00000000ff"
09:26:06 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:26:06 TYA: Heartbeat
09:26:17 TYA: Send "55aa00000000ff"
09:26:17 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:26:17 TYA: Heartbeat
09:26:25 WIF: Checking connection...
09:26:28 TYA: Send "55aa00000000ff"
09:26:28 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:26:28 TYA: Heartbeat
09:26:39 TYA: Send "55aa00000000ff"
09:26:39 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:26:39 TYA: Heartbeat
09:26:45 WIF: Checking connection...
09:26:50 TYA: Send "55aa00000000ff"
09:26:50 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:26:50 TYA: Heartbeat
09:26:56 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:26:56","Uptime":"2T20:35:13","UptimeSec":246913,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"POWER":"ON","Dimmer":65,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-49,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:27:01 TYA: Send "55aa00000000ff"
09:27:01 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:01 TYA: Heartbeat
09:27:05 WIF: Checking connection...
09:27:12 TYA: Send "55aa00000000ff"
09:27:12 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:12 TYA: Heartbeat
09:27:23 TYA: Send "55aa00000000ff"
09:27:23 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:23 TYA: Heartbeat
09:27:25 WIF: Checking connection...
09:27:34 TYA: Send "55aa00000000ff"
09:27:34 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:34 TYA: Heartbeat
09:27:45 WIF: Checking connection...
09:27:45 TYA: Send "55aa00000000ff"
09:27:45 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:45 TYA: Heartbeat
09:27:56 TYA: Send "55aa00000000ff"
09:27:56 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:27:56 TYA: Heartbeat
09:28:05 WIF: Checking connection...
09:28:07 TYA: Send "55aa00000000ff"
09:28:07 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:28:07 TYA: Heartbeat
09:28:12 CMD: setoption43
09:28:12 SRC: WebConsole from 192.168.1.133
09:28:12 CMD: Group 0, Index 43, Command "SETOPTION", Data ""
09:28:12 RSL: tasmota/stat/RESULT = {"SetOption43":0}
09:28:18 TYA: Send "55aa00000000ff"
09:28:18 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:28:18 TYA: Heartbeat
09:28:23 CMD: setoption54
09:28:23 SRC: WebConsole from 192.168.1.133
09:28:23 CMD: Group 0, Index 54, Command "SETOPTION", Data ""
09:28:23 RSL: tasmota/stat/RESULT = {"SetOption54":"OFF"}
09:28:25 WIF: Checking connection...
09:28:29 TYA: Send "55aa00000000ff"
09:28:29 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:28:29 TYA: Heartbeat
09:28:33 CMD: setoption69
09:28:33 SRC: WebConsole from 192.168.1.133
09:28:33 CMD: Group 0, Index 69, Command "SETOPTION", Data ""
09:28:34 RSL: tasmota/stat/RESULT = {"SetOption69":"OFF"}
09:28:40 TYA: Send "55aa00000000ff"
09:28:40 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:28:40 TYA: Heartbeat
09:28:45 WIF: Checking connection...
09:28:51 TYA: Send "55aa00000000ff"
09:28:51 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:28:51 TYA: Heartbeat
09:28:53 CMD: dimmerrange 10,255
09:28:53 SRC: WebConsole from 192.168.1.133
09:28:53 CMD: Group 0, Index 1, Command "DIMMERRANGE", Data "10,255"
09:28:53 RSL: tasmota/stat/RESULT = {"DimmerRange":{"Min":10,"Max":255}}
09:28:53 TYA: Send dim value=79 (id=3)
09:28:53 TYA: Send "55aa00060008030200040000004f65"
09:28:53 {"TuyaReceived":{"Data":"55AA00070008030200040000005067","Cmnd":7,"CmndData":"0302000400000050","DpType2Id3":80,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000050"}}}
09:28:53 TYA: fnId=21 is set for dpId=3
09:28:53 TYA: RX Dim State=80
09:28:54 CFG: Saved to flash at F7, Count 587, Bytes 4096
09:29:02 TYA: Send "55aa00000000ff"
09:29:02 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:02 TYA: Heartbeat
09:29:05 WIF: Checking connection...
09:29:07 CMD: dimmer 0
09:29:07 SRC: WebConsole from 192.168.1.133
09:29:07 CMD: Group 0, Index 1, Command "DIMMER", Data "0"
09:29:07 SRC: Light
09:29:07 TYA: Send dim skipped value=0
09:29:07 TYA: Send "55aa0006000501010001000d"
09:29:08 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:29:07","Uptime":"2T20:37:24","UptimeSec":247044,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":99,"MqttCount":0,"POWER":"OFF","Dimmer":0,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:29:08 RSL: tasmota/stat/RESULT = {"POWER":"OFF","Dimmer":0}
09:29:08 {"TuyaReceived":{"Data":"55AA0007000501010001000E","Cmnd":7,"CmndData":"0101000100","DpType1Id1":0,"1":{"DpId":1,"DpIdType":1,"DpIdData":"00"}}}
09:29:08 TYA: fnId=11 is set for dpId=1
09:29:08 TYA: RX Relay-1 --> MCU State: Off Current State:Off
09:29:08 TYA: Send dim skipped value=0
09:29:08 CFG: Saved to flash at F6, Count 588, Bytes 4096
09:29:13 TYA: Send "55aa00000000ff"
09:29:13 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:13 TYA: Heartbeat
09:29:23 CMD: dimmer 50
09:29:23 SRC: WebConsole from 192.168.1.133
09:29:23 CMD: Group 0, Index 1, Command "DIMMER", Data "50"
09:29:23 SRC: Light
09:29:23 TYA: Send dim value=39 (id=3)
09:29:23 TYA: Send "55aa0006000803020004000000273d"
09:29:23 TYA: Send "55aa0006000501010001010e"
09:29:23 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:29:23","Uptime":"2T20:37:40","UptimeSec":247060,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":19,"MqttCount":0,"POWER":"ON","Dimmer":50,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:29:23 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":50}
09:29:23 {"TuyaReceived":{"Data":"55AA0007000803020004000000273E","Cmnd":7,"CmndData":"0302000400000027","DpType2Id3":39,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000027"}}}
09:29:23 TYA: fnId=21 is set for dpId=3
09:29:23 TYA: RX Dim State=39
09:29:23 SRC: Switch
09:29:23 CMD: Group 0, Index 3, Command "DIMMER", Data "15"
09:29:23 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:29:23","Uptime":"2T20:37:40","UptimeSec":247060,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":19,"MqttCount":0,"POWER":"ON","Dimmer":15,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:29:23 TYA: Send dim skipped value=2
09:29:23 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":15}
09:29:23 {"TuyaReceived":{"Data":"55AA0007000501010001010F","Cmnd":7,"CmndData":"0101000101","DpType1Id1":1,"1":{"DpId":1,"DpIdType":1,"DpIdData":"01"}}}
09:29:23 TYA: fnId=11 is set for dpId=1
09:29:23 TYA: RX Relay-1 --> MCU State: On Current State:On
09:29:24 TYA: Send "55aa00000000ff"
09:29:24 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:24 TYA: Heartbeat
09:29:24 CFG: Saved to flash at F5, Count 589, Bytes 4096
09:29:25 WIF: Checking connection...
09:29:30 CMD: dimmer 65
09:29:30 SRC: WebConsole from 192.168.1.133
09:29:30 CMD: Group 0, Index 1, Command "DIMMER", Data "65"
09:29:31 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T09:29:30","Uptime":"2T20:37:47","UptimeSec":247067,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"POWER":"ON","Dimmer":65,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
09:29:31 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":65}
09:29:31 TYA: Send dim value=79 (id=3)
09:29:31 TYA: Send "55aa00060008030200040000004f65"
09:29:31 {"TuyaReceived":{"Data":"55AA00070008030200040000005067","Cmnd":7,"CmndData":"0302000400000050","DpType2Id3":80,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000050"}}}
09:29:31 TYA: fnId=21 is set for dpId=3
09:29:31 TYA: RX Dim State=80
09:29:31 CFG: Saved to flash at F4, Count 590, Bytes 4096
09:29:35 TYA: Send "55aa00000000ff"
09:29:35 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:35 TYA: Heartbeat
09:29:46 WIF: Checking connection...
09:29:46 TYA: Send "55aa00000000ff"
09:29:46 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:46 TYA: Heartbeat
09:29:57 TYA: Send "55aa00000000ff"
09:29:57 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:29:57 TYA: Heartbeat
09:30:06 WIF: Checking connection...
09:30:08 TYA: Send "55aa00000000ff"
09:30:08 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:30:08 TYA: Heartbeat
09:30:19 TYA: Send "55aa00000000ff"
09:30:19 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:30:19 TYA: Heartbeat
09:30:26 WIF: Checking connection...
09:30:30 TYA: Send "55aa00000000ff"
09:30:30 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:30:30 TYA: Heartbeat
09:30:41 TYA: Send "55aa00000000ff"
09:30:41 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:30:41 TYA: Heartbeat
09:30:46 WIF: Checking connection...
09:30:52 TYA: Send "55aa00000000ff"
09:30:52 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:30:52 TYA: Heartbeat
09:31:03 TYA: Send "55aa00000000ff"
09:31:03 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:31:03 TYA: Heartbeat
09:31:06 WIF: Checking connection...
09:31:14 TYA: Send "55aa00000000ff"
09:31:14 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:31:14 TYA: Heartbeat
09:31:25 TYA: Send "55aa00000000ff"
09:31:25 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
09:31:25 TYA: Heartbeat
