08:50:57 CMD: dimmer 0
08:50:57 SRC: WebConsole from 192.168.1.133
08:50:57 CMD: Group 0, Index 1, Command "DIMMER", Data "0"
08:50:57 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:50:57","Uptime":"2T19:59:14","UptimeSec":244754,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Dimmer":0,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
08:50:57 RSL: tasmota/stat/RESULT = {"POWER":"OFF","Dimmer":0}
08:50:57 TYA: Send dim skipped value=0
08:50:58 CFG: Saved to flash at F4, Count 574, Bytes 4096
08:51:01 WIF: Checking connection...
08:51:05 TYA: Send "55aa00000000ff"
08:51:05 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
08:51:05 TYA: Heartbeat
08:51:16 TYA: Send "55aa00000000ff"
08:51:16 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
08:51:16 TYA: Heartbeat
08:51:21 WIF: Checking connection...
08:51:27 CMD: dimmer 0
08:51:27 SRC: WebConsole from 192.168.1.133
08:51:27 CMD: Group 0, Index 1, Command "DIMMER", Data "0"
08:51:27 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:51:27","Uptime":"2T19:59:44","UptimeSec":244784,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER":"OFF","Dimmer":0,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
08:51:27 RSL: tasmota/stat/RESULT = {"POWER":"OFF","Dimmer":0}
08:51:27 TYA: Send dim skipped value=0
08:51:27 TYA: Send "55aa00000000ff"
08:51:27 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
08:51:27 TYA: Heartbeat
08:51:34 CMD: dimmer 50
08:51:34 SRC: WebConsole from 192.168.1.133
08:51:34 CMD: Group 0, Index 1, Command "DIMMER", Data "50"
08:51:34 SRC: Light
08:51:34 TYA: Send dim value=40 (id=3)
08:51:34 TYA: Send "55aa0006000803020004000000283e"
08:51:34 TYA: Send "55aa0006000501010001010e"
08:51:34 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:51:34","Uptime":"2T19:59:51","UptimeSec":244791,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":19,"MqttCount":0,"POWER":"ON","Dimmer":50,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
08:51:34 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":50}
08:51:34 {"TuyaReceived":{"Data":"55AA0007000803020004000000283F","Cmnd":7,"CmndData":"0302000400000028","DpType2Id3":40,"3":{"DpId":3,"DpIdType":2,"DpIdData":"00000028"}}}
08:51:34 TYA: fnId=21 is set for dpId=3
08:51:34 TYA: RX Dim State=40
08:51:34 SRC: Switch
08:51:34 CMD: Group 0, Index 3, Command "DIMMER", Data "16"
08:51:34 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:51:34","Uptime":"2T19:59:51","UptimeSec":244791,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":19,"MqttCount":0,"POWER":"ON","Dimmer":16,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
08:51:34 TYA: Send dim skipped value=2
08:51:34 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":16}
08:51:34 {"TuyaReceived":{"Data":"55AA0007000501010001010F","Cmnd":7,"CmndData":"0101000101","DpType1Id1":1,"1":{"DpId":1,"DpIdType":1,"DpIdData":"01"}}}
08:51:34 TYA: fnId=11 is set for dpId=1
08:51:34 TYA: RX Relay-1 --> MCU State: On Current State:On
08:51:35 CFG: Saved to flash at FB, Count 575, Bytes 4096
08:51:38 TYA: Send "55aa00000000ff"
08:51:38 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
08:51:38 TYA: Heartbeat
08:51:40 CMD: dimmer 100
08:51:40 SRC: WebConsole from 192.168.1.133
08:51:40 CMD: Group 0, Index 1, Command "DIMMER", Data "100"
08:51:41 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:51:40","Uptime":"2T19:59:57","UptimeSec":244797,"Heap":25,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":0,"POWER":"ON","Dimmer":100,"Fade":"OFF","Speed":20,"LedTable":"ON","Wifi":{"AP":1,"SSId":"KRAUSHOUSE","BSSId":"60:38:E0:77:F0:FA","Channel":11,"RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:06"}}
08:51:41 RSL: tasmota/stat/RESULT = {"POWER":"ON","Dimmer":100}
08:51:41 TYA: Send dim value=255 (id=3)
08:51:41 TYA: Send "55aa0006000803020004000000ff15"
08:51:41 {"TuyaReceived":{"Data":"55AA0007000803020004000000FF16","Cmnd":7,"CmndData":"03020004000000FF","DpType2Id3":255,"3":{"DpId":3,"DpIdType":2,"DpIdData":"000000FF"}}}
08:51:41 TYA: fnId=21 is set for dpId=3
08:51:41 TYA: RX Dim State=255
08:51:41 CFG: Saved to flash at FA, Count 576, Bytes 4096
08:51:42 WIF: Checking connection...
08:51:49 TYA: Send "55aa00000000ff"
08:51:49 {"TuyaReceived":{"Data":"55AA000000010101","Cmnd":0,"CmndData":"01"}}
08:51:49 TYA: Heartbeat
08:51:56 RSL: tasmota/tele/STATE = {"Time":"2020-07-26T08:51:56","Uptime":"2T20:00:13","UptimeS
