I have been modifying a child/parent example driver from @mike.maxwell (Generic Component Parent Demo), trying to get multiple child switches under a single parent. It would help if I had a driver I could lean from that already had multiple switches. Can anyone point me to a multiple-switch parent/child driver I can play with?
They are not multiple switches but my sendmail v3 parent device creates and deletes multiple child devices.
* simple sendmail .. lg kahn kahn@lgk.com
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <https://www.gnu.org/licenses/>.
* v 2.1 added desciprtive text and cleaned up debugging
* v 2.2 added hostname option and lookup ip if blank.
* v 2.3 added better checking for end of send to make sure it is closing cleanly
* v 2.4 add serial queueing so that a new connect waits while old finishes.. set timeout to 1 minute to wait. if email is not finished by
* then close connection and start new one. Also add state.lastCommand to follow the attribute as that seems more reliable.
* to this function telling me socket is closed but it obviously is not because responses are still asynchronously coming basck after!
* This "Stream is closed" messages seems to always come out after the quit command so it appears to be a status message not really an error
* v 2.4.2. try to workaround the check i had for the goodbye/bye message .. I was checkiong the value string on code 221 which was not a good
* approach as various servers can return differnent strings here. Unfortunately 221 just means remote server is closing so need to checkt
* that the message was sent and it is 221,
* v 2.4.3 true concurrency and queue using a thread safe data structure concurrentlinkedqueue and also mutex (thanks to erktrek)
* tested with up to 8 messages
* When one message finishes it checks the queue, and delivers any other remaining.. also schedules a rerun when busy and one is added to the queue.
* also serialize the setting and checking of the state.lastCommand as this is used to keep track of the async status of the commands
This file has been truncated. show original
mbishop
December 27, 2022, 8:47pm
3
You could look at Single Active Switch , a parent which creates many child switches and ensures at most one is on at any time.
Did you try the Hubitat official Github? There are many examples in there.
I was able to add my 3 child switches that trigger MQTT on/off requests back through the parent.
Thanks for the help!!
system
Closed
December 30, 2023, 2:15pm
6
