I have two Aeon HEM v1 power monitors. I was using one for years w/out issue and then it started not reporting consistently. I assumed it was finally going and set it aside and set up my second Aeon HEM v1. Now the second one has stopped reporting as well, nothing since the 22nd, after a few months. Connection to the hub looks normal, nothing Z-Wave (new or removed devices) has changed for months and months. .
Just wanted to see if anyone has run into this w/the v1 HEMs and found anything other than the units are just finally dying...they have been around for a long time.
Dammit...maybe I should send you one of mine to see if it works at your place. Just seems really odd that both would stop reporting so similarly. The both were/are directly connected to the hub.
What driver are you using...Aeon Home Energy Meter?
Thinking I'll try your driver to isolate any issues w/the (very old) driver I'm using w/the newest versions of the hub FW. And does the Aeon Home Energy Meter driver support reporting both clamps? I switched to the Aeon HEM driver and only get one power report - "Energy."
