Is there a way to create a single rule to turn on and off a T-Stat at different times each day Creating the rule to come on Monday thru Friday at 5AM to 68 deg is the easy part. Adding different trigger times is easy, how to link them individually to each action now that's the problem or do I have to create a separate rule for each action I want it to complete?
Two rules, each triggered at your specific time that each run your specific actions, is simple. There is no inherent reason to prefer a single rule, and multiple, smaller rules are generally easier to write and troubleshoot than fewer, larger rules, so there is some reason not to prefer it.
But this case sounds simple enough. A trigger on your earlier time with the actions you want, plus a "Wait for event" for the other "certain time" followed by your other actions would be an easy way. For more help, I'd suggest sharing what you have now or what you create if you get stuck -- but, again, if you already have two rules that are working, I wouldn't suggest changing anything for its own sake.
