MQTT Tuya WiFi Fan/Light Driver for Local Control
Hi all, I have this device installed in my home QIACHIP Upgrade Universal WIFI Ceiling Fan and I wanted to get local control over it using MQTT. Of course its a Tuya device. So, I have a NAS from QNAP which I run Container Station and created a MQTT server and used MQTT Client for local Tuya devices by Volker76 on github here. Follow the instructions there on setup. Here's the YML configuration file I used.
YML Code:
services:
  tuya-mqtt:
    image: volkerhaensel/tuya_mqtt.net:latest
    container_name: tuya-mqtt
    networks:
      macvlan_net:
        ipv4_address: YOUR.IP.ADDRESS.HERE   # Assign a unique LAN IP for Tuya-MQTT (e.g., 192.168.1.230)
    volumes:
      - tuya.net_config:/app/DataDir         # DataDir is case-sensitive
    restart: unless-stopped
    expose:
      - "80/tcp"                             # Web UI → http://YOUR.IP.ADDRESS.HERE
      - "6666/udp"                           # Tuya discovery (unencrypted)
      - "6667/udp"                           # Tuya discovery (encrypted)
    healthcheck:
      test: ["CMD-SHELL", "wget -q -O /dev/null http://localhost:80 || exit 1"]
      interval: 60s
      timeout: 5s
      retries: 5
      start_period: 20s
  mosquitto:
    image: eclipse-mosquitto:2
    container_name: tuya-mosquitto
    networks:
      macvlan_net:
        ipv4_address: YOUR.IP.ADDRESS.HERE   # Assign a DIFFERENT unique LAN IP for Mosquitto (e.g., 192.168.1.232)
    expose:
      - "1883/tcp"                           # Clients connect → tcp://YOUR.IP.ADDRESS.HERE:1883
    volumes:
      - ./mosquitto:/mosquitto               # Place mosquitto.conf in ./mosquitto/config/
networks:
  macvlan_net:
    driver: macvlan
    driver_opts:
      parent: br0                            # Change if your LAN interface is different
    ipam:
      config:
        - subnet: 192.168.1.0/24             # Match your LAN subnet (change if needed)
          gateway: 192.168.1.1               # Change to your router’s gateway IP
volumes:
  tuya.net_config:
I entered into the Tuya-MQTT, set that up as per Volker76's github page. I was able to identified the device in my network and connected to the device. Of note, you may need a Tuya IOT login for this, again, see Volker76's github page for details.
After the fact I created this Driver using our AI overlord's help. Installed the driver into Hubitat, added a Virtual Device using the driver and coifgured the device under the device's preferences. It will ask for your mqtt Mosquitto server IP address (not the MQTT-Tuya IP address) and the Device ID, IP or Name.
You initialize and then you will then be able to control your Tuya device.
Driver code:
 * Tuya MQTT.NET Fan+Light (Local) + DP Learn
 * Platform: Hubitat
 * Target bridge: volkerhaensel/tuya_mqtt.net
 * License: MIT
import groovy.transform.Field
import groovy.json.JsonOutput
@Field static final Integer PRESENCE_TIMEOUT_SEC        = 3600
@Field static final Integer RESEND_DELAY_SEC            = 2
@Field static final Integer WATCHDOG_PERIOD_SEC         = 30
@Field static final Integer BACKOFF_MIN_SEC             = 5
@Field static final Integer BACKOFF_MAX_SEC             = 300
@Field static final Integer CONNECT_STALL_SEC           = 20
@Field static final Integer RESUBSCRIBE_AFTER_SILENCE   = 300
@Field static final Integer OBSERVED_MAX_DPS            = 64
@Field static final List<String>  SPEED_ORDER = ["off", "low", "medium", "high"]
@Field static final List<Integer> DPs_PRIMARY = [1, 3, 9]
@Field static final String RECONNECT_JOB = "reconnectStep"
@Field static final String BOOTSTRAP_TOPIC_KEY = "__bootstrapWildcard__"
@Field static final String CMD_SEGMENT = "command"
metadata {
  definition(name: "Tuya MQTT.NET Fan+Light (DP Learn)", namespace: "public", author: "you") {
    capability "Initialize"
    capability "Switch"
    capability "FanControl"
    capability "Refresh"
    capability "PresenceSensor"
    command "cycleSpeed"
    command "reconnectNow"
    command "clearObservedDPs"
    command "clearLearnedRoot"
    attribute "supportedFanSpeeds", "JSON_OBJECT"
    attribute "speed", "STRING"
    attribute "lastSeen", "STRING"
    attribute "mqttStatus", "STRING"
    attribute "activeRoot", "STRING"
    attribute "mqttConnected", "STRING"
    attribute "observedDPs", "JSON_OBJECT"
    attribute "dpLast", "JSON_OBJECT"
  preferences {
    input name: "brokerHost", type: "text", title: "MQTT Broker Host", defaultValue: "192.168.4.232", required: true
    input name: "brokerPort", type: "text", title: "MQTT Broker Port", defaultValue: "1883", required: true
    input name: "username", type: "text", title: "MQTT Username (optional)"
    input name: "password", type: "password", title: "MQTT Password (optional)"
    input name: "baseTopic", type: "text", title: "tuya_mqtt.net MQTT Topic / Base topic", defaultValue: ""
    input name: "identifierMode", type: "enum", title: "Identifier Mode",
      options: ["Auto", "ID/Name", "IP"], defaultValue: "ID/Name"
    input name: "deviceId", type: "text", title: "tuya_mqtt.net Device Name or ID", defaultValue: "Fan", required: false
    input name: "deviceIp", type: "text", title: "Device IP (optional)", required: false
    input name: "enableLearning", type: "bool", title: "Learn active MQTT root from wildcard subscription", defaultValue: false
    input name: "legacyCommandTopic", type: "bool", title: "Also publish legacy command/n topics", defaultValue: false
    input name: "createLightChild", type: "bool", title: "Expose DP9 as child light", defaultValue: true
    input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def installed() { initialize() }
def updated() { initialize() }
def uninstalled() {
  try { interfaces.mqtt.disconnect() } catch (ignored) {}
  unschedule()
def initialize() {
  unschedule()
  validatePrefs()
  def prefRoots = candidateIdentifiers().collect { rootFor(it) }.findAll { it }
  if (state.activeRoot && prefRoots && !prefRoots.contains(state.activeRoot as String)) {
    state.remove("activeRoot")
  state.lastSeenEpoch = 0L
  state.lastMqttOkEpoch = now()
  state.connected = false
  state.remove("connectingAt")
  state.backoff = BACKOFF_MIN_SEC
  state.reconnectAtEpoch = 0L
  state.subscribeRetryAt = 0L
  state.lastResubscribeEpoch = now()
  state.remove("pendingSpeedRaw")
  state.remove("stabilizeUntil")
  if (state.observed == null) state.observed = []
  if (state.dpLast == null) state.dpLast = [:]
  sendEvent(name: "mqttConnected", value: "false")
  sendEvent(name: "activeRoot", value: state.activeRoot ?: "")
  connectMqtt()
  runIn(3, "publishSupportedSpeeds")
  runIn(4, "ensureLightChild")
  runIn(5, "startWatchdogLoop")
  runEvery1Minute("presenceTick")
  runIn(10, "connectionGuard")
  if (logEnable) log.debug "Initialized Tuya MQTT.NET Fan+Light driver"
def refresh() {
  if (logEnable) log.debug "Refresh requested; waiting for next MQTT DP/TS update"
  subscribeTopics()
def clearObservedDPs() {
  state.observed = []
  state.dpLast = [:]
  sendEvent(name: "observedDPs", value: "[]", isStateChange: true)
  sendEvent(name: "dpLast", value: "{}", isStateChange: true)
def clearLearnedRoot() {
  sendEvent(name: "activeRoot", value: "", isStateChange: true)
  subscribeTopics()
private boolean mqttIsConnected() {
  return (state.connected == true) ||
         (state.connected?.toString() == "true") ||
         (device.currentValue("mqttConnected")?.toString() == "true")
private void connectMqtt() {
  final Integer portInt = safePort()
  final String uri = "tcp://${brokerHost}:${portInt}"
  final String clientId = "hubitat-tuya-fan-${device.id}"
  if (logEnable) log.debug "Connecting MQTT ${uri} as ${clientId}"
  try {
    sendEvent(name: "mqttStatus", value: "connecting")
    state.connectingAt = now()
    interfaces.mqtt.connect(uri, clientId, username ?: null, password ?: null)
  } catch (e) {
    if (logEnable) log.warn "MQTT connect threw: ${e?.message ?: e}"
    scheduleReconnect("connect threw")
private void scheduleReconnect(String reason = null) {
  if (mqttIsConnected()) return
  long nowMs = now()
  long nextAt = (state.reconnectAtEpoch ?: 0L) as long
  if (nextAt > nowMs) {
    if (logEnable && reason) {
      long remaining = Math.max(1L, (nextAt - nowMs) / 1000L)
      log.debug "Reconnect already scheduled in ${remaining}s; not rescheduling (${reason})"
    return
  Integer delay = (state.backoff ?: BACKOFF_MIN_SEC) as Integer
  delay = Math.max(BACKOFF_MIN_SEC, Math.min(delay, BACKOFF_MAX_SEC))
  Integer jitter = Math.max(1, (int)(delay * 0.2))
  Integer withJitter = Math.max(1, delay + (new Random().nextInt(jitter * 2 + 1) - jitter))
  try { unschedule(RECONNECT_JOB) } catch (ignored) {}
  if (logEnable) {
    log.warn "Scheduling reconnect in ${withJitter}s (backoff=${delay}s)" + (reason ? " reason=${reason}" : "")
  runIn(withJitter, RECONNECT_JOB)
  state.reconnectAtEpoch = nowMs + (withJitter * 1000L)
  state.backoff = Math.min(delay * 2, BACKOFF_MAX_SEC)
private void immediateReconnect(String reason = null) {
  if (logEnable) log.warn "Immediate reconnect" + (reason ? " (${reason})" : "")
  pauseExecution(250)
  connectMqtt()
def reconnectStep() {
  if (mqttIsConnected()) {
    if (logEnable) log.debug "Reconnect skipped: already connected"
    return
  pauseExecution(250)
  connectMqtt()
def reconnectNow() {
  if (logEnable) log.warn "Manual reconnect requested"
  immediateReconnect("manual")
private boolean publishMqtt(String topic, String payload, Boolean retain = false, Integer qos = 1) {
  if (!mqttIsConnected()) {
    if (logEnable) log.warn "Publish blocked while disconnected: ${topic}"
    scheduleReconnect("publish while disconnected")
    return false
  try {
    interfaces.mqtt.publish(topic, payload, qos, retain)
    return true
  } catch (e) {
    String msg = (e?.message ?: e?.toString() ?: "").toLowerCase()
    if (msg.contains("client is not connected")) {
      immediateReconnect("publish: client not connected")
    } else {
      if (logEnable) log.warn "Publish failed ${topic}: ${e?.message ?: e}"
      scheduleReconnect("publish exception")
    return false
private String rootFor(String ident) {
  def b = cleanTopicPart(baseTopic)
  def i = cleanTopicPart(ident)
  if (!i) return null
  return b ? "${b}/${i}" : i
private List<String> candidateIdentifiers() {
  def ids = []
  def mode = (identifierMode ?: "ID/Name").toString()
  String did = deviceId?.trim()
  String dip = deviceIp?.trim()
  switch (mode) {
    case "ID/Name":
      if (did) ids << did
      break
    case "IP":
      if (dip) ids << dip
      break
    default:
      if (did) ids << did
      if (!did && dip) ids << dip
      break
  return ids.findAll { it }.unique()
private List<String> configuredRoots() {
  def roots = []
  if (state.activeRoot) roots << (state.activeRoot as String)
  candidateIdentifiers().each { ident ->
    def r = rootFor(ident)
    if (r) roots << r
  return roots.findAll { it }.unique()
private String activeRootOrNull() {
  if (state.activeRoot) return state.activeRoot as String
  def roots = configuredRoots()
  return roots ? roots[0] : null
private String tStateDP(String root, int dp) { "${root}/DP${dp}" }
private String tStateDps(String root, int dp) { "${root}/dps/${dp}" }
private String tCmdDP(String root, int dp) { "${root}/DP${dp}/${CMD_SEGMENT}" }
private String tCmdLegacy(String root, int dp) { "${root}/${CMD_SEGMENT}/${dp}" }
private String tDeviceTs(String root) { "${root}/TS" }
private boolean topicMatchesDp(String topic, String root, int dp) {
  return topic == tStateDP(root, dp) || topic == tStateDps(root, dp)
def subscribeTopics() {
    long nowMs = now()
    long retryAt = (state.subscribeRetryAt ?: 0L) as long
    if (retryAt <= nowMs) {
      state.subscribeRetryAt = nowMs + 3000L
      runIn(3, "subscribeTopics")
    return
  if (roots) {
    roots.each { r -> subscribeRoot(r) }
    if (logEnable) log.debug "Subscribed to roots: ${roots}"
  if (learningEnabled()) {
    def wild = bootstrapWildcard()
    try {
      interfaces.mqtt.subscribe(wild)
      state[BOOTSTRAP_TOPIC_KEY] = wild
      if (logEnable) log.debug "Root learning subscribed to ${wild}"
    } catch (e) {
      handleSubscribeFailure(e, "bootstrap subscribe")
private void subscribeRoot(String root) {
  try {
    interfaces.mqtt.subscribe("${root}/#")
    DPs_PRIMARY.each { dp ->
      interfaces.mqtt.subscribe(tStateDP(root, dp))
      interfaces.mqtt.subscribe(tStateDps(root, dp))
    interfaces.mqtt.subscribe(tDeviceTs(root))
  } catch (e) {
    handleSubscribeFailure(e, "subscribe ${root}")
private void handleSubscribeFailure(def e, String context) {
    immediateReconnect("${context}: client not connected")
  } else {
    if (logEnable) log.warn "${context} failed: ${e?.message ?: e}"
    scheduleReconnect("${context} failed")
private String bootstrapWildcard() {
  return b ? "${b}/#" : "#"
private void learnActiveRootFromTopic(String topic) {
  if (isCommandTopic(topic)) return
  String root = null
  def m = (topic =~ /^(.*)\/DP(\d+)$/)
  if (m.matches()) root = m[0][1]
  if (!root) {
    m = (topic =~ /^(.*)\/dps\/(\d+)$/)
  if (!root) return
  state.activeRoot = root
  sendEvent(name: "activeRoot", value: root, isStateChange: true)
  if (logEnable) log.warn "Active MQTT root learned: ${root}"
  def wild = (state[BOOTSTRAP_TOPIC_KEY] ?: null)
  if (wild && wild != "${root}/#") {
    try { interfaces.mqtt.unsubscribe(wild) } catch (ignored) {}
    state.remove(BOOTSTRAP_TOPIC_KEY)
  if (mqttIsConnected()) subscribeRoot(root)
def mqttClientStatus(String status) {
  sendEvent(name: "mqttStatus", value: status)
  if (logEnable) log.debug "MQTT status: ${status}"
  String s = (status ?: "").toString().toLowerCase()
  boolean ok =
    s.contains("connection succeeded") ||
    s.contains("connection succeed") ||
    s.contains("succeeded") ||
    s.contains("succeed")
  boolean bad =
    s.startsWith("error") ||
    s.contains("lost") ||
    s.contains("disconnected") ||
    s.contains("connection failed") ||
    s.contains("fail") ||
    s.contains("client is not connected")
  if (ok) {
    state.connected = true
    sendEvent(name: "mqttConnected", value: "true")
    presenceMark(true)
    try { subscribeTopics() } catch (ignored) {}
    runIn(2, "subscribeTopics")
    runIn(30, "connectionGuard")
    return
  if (bad) {
    if (s.contains("client is not connected")) {
      immediateReconnect("status: client not connected")
    } else {
      scheduleReconnect("mqttClientStatus bad: ${status}")
    return
  def msg = interfaces.mqtt.parseMessage(description)
  if (!msg?.topic) return
  final String topic = msg.topic.toString()
  final String payload = (msg.payload == null) ? "" : msg.payload.toString().trim()
  if (!state.activeRoot) learnActiveRootFromTopic(topic)
  final String root = activeRootOrNull()
  if (!root) return
  if (!topic.startsWith(root + "/")) return
  final String rel = topic.substring(root.length() + 1)
  if (rel == "TS") {
    markSeen()
    return
  Integer observedDp = dpFromRelative(rel)
  if (observedDp != null) {
    markSeen()
    rememberObservedDp(observedDp, payload)
  if (topicMatchesDp(topic, root, 1)) {
    final boolean onNow = asBool(payload)
    sendEvent(name: "switch", value: onNow ? "on" : "off")
    if (!onNow) sendEvent(name: "speed", value: "off")
    return
  if (topicMatchesDp(topic, root, 3)) {
    final String raw = payload.replaceAll("\"", "")
    final String name = (raw == "1") ? "low" : (raw == "2") ? "medium" : (raw == "3") ? "high" : "off"
    final long nowMs = now()
    if (state.pendingSpeedRaw && (state.pendingSpeedRaw in ["2", "3"]) && raw == "1") {
      final long until = (state.stabilizeUntil ?: 0L) as long
      if (nowMs <= until) {
        publishDP3(state.pendingSpeedRaw as String)
        return
    sendEvent(name: "speed", value: name)
    if (state.pendingSpeedRaw && raw == state.pendingSpeedRaw) {
    return
  if (topicMatchesDp(topic, root, 9)) {
    childLight()?.sendEvent(name: "switch", value: onNow ? "on" : "off")
    return
def on() {
  sendEvent(name: "switch", value: "on")
  publishDP1(true)
def off() {
  publishDP1(false)
  sendEvent(name: "switch", value: "off")
def setSpeed(String speed) {
  speed = (speed ?: "off").toLowerCase()
  switch (speed) {
    case "off":
      off()
      return
    case "low":
    case "medium":
    case "high":
      final String v = (speed == "low") ? "1" : (speed == "medium") ? "2" : "3"
      publishDP1(true)
      state.pendingSpeedRaw = v
      state.stabilizeUntil = now() + 5000
      runInMillisSafe(500, "publishInitialSpeed")
      runIn(RESEND_DELAY_SEC, "reassertPendingSpeed")
      sendEvent(name: "speed", value: speed)
      return
    default:
      setSpeed("medium")
      return
def cycleSpeed() {
  def cur = (device.currentValue("speed") ?: "off").toLowerCase()
  def idx = SPEED_ORDER.indexOf(cur)
  if (idx < 0) idx = 0
  setSpeed(SPEED_ORDER[(idx + 1) % SPEED_ORDER.size()])
def publishInitialSpeed() {
  def v = state.pendingSpeedRaw
  if (v) publishDP3(v as String)
def reassertPendingSpeed() {
private void publishDP1(boolean val) {
  if (!root) {
    log.warn "No active MQTT root for DP1 command"
    return
  final String p = val ? "true" : "false"
  publishMqtt(tCmdDP(root, 1), p, false, 1)
  if (legacyCommandTopic == true) {
    publishMqtt(tCmdLegacy(root, 1), p, false, 1)
private void publishDP3(String v) {
  if (!root) {
    log.warn "No active MQTT root for DP3 command"
    return
  final String payload = JsonOutput.toJson((v ?: "").replaceAll("\"", ""))
  publishMqtt(tCmdDP(root, 3), payload, false, 1)
    publishMqtt(tCmdLegacy(root, 3), payload, false, 1)
private void publishDP9(boolean val) {
  if (!root) {
    log.warn "No active MQTT root for DP9 command"
    return
  publishMqtt(tCmdDP(root, 9), p, false, 1)
    publishMqtt(tCmdLegacy(root, 9), p, false, 1)
private void publishSupportedSpeeds() {
  sendEvent(name: "supportedFanSpeeds", value: '["off","low","medium","high"]', isStateChange: true)
private void ensureLightChild() {
  if (createLightChild != true) return
  if (!childLight()) {
    final String dni = "${device.deviceNetworkId}-light"
    try {
      addChildDevice("hubitat", "Generic Component Switch", dni,
        [name: "${device.displayName} Light", label: "${device.displayName} Light", isComponent: true])
    } catch (e) {
      log.warn "Cannot create child light: ${e}"
private childLight() {
  getChildDevice("${device.deviceNetworkId}-light")
def componentOn(cd) {
  publishDP9(true)
  childLight()?.sendEvent(name: "switch", value: "on")
def componentOff(cd) {
  publishDP9(false)
  childLight()?.sendEvent(name: "switch", value: "off")
def componentRefresh(cd) {}
private void markSeen() {
  state.lastSeenEpoch = now()
  sendEvent(name: "lastSeen", value: formatEpoch(state.lastSeenEpoch))
  presenceMark(true)
private void presenceTick() {
  final long last = (state.lastSeenEpoch ?: 0L) as long
  if (last <= 0L) {
    presenceMark(mqttIsConnected())
    return
  final long ageS = (now() - last) / 1000L
  presenceMark(ageS <= PRESENCE_TIMEOUT_SEC)
private void presenceMark(boolean present) {
  final String want = present ? "present" : "not present"
  if (device.currentValue("presence") != want) {
    sendEvent(name: "presence", value: want)
def startWatchdogLoop() {
  runIn(Math.max(5, WATCHDOG_PERIOD_SEC), "watchdogTick")
def watchdogTick() {
    scheduleReconnect("watchdog not connected")
  } else {
    final long lastOk = (state.lastMqttOkEpoch ?: now()) as long
    final long idleSec = (now() - lastOk) / 1000L
    final long lastSub = (state.lastResubscribeEpoch ?: now()) as long
    final long sinceSub = (now() - lastSub) / 1000L
    if (idleSec >= RESUBSCRIBE_AFTER_SILENCE && sinceSub >= RESUBSCRIBE_AFTER_SILENCE) {
      if (logEnable) log.warn "MQTT quiet for ${idleSec}s; resubscribing without recycling socket"
      subscribeTopics()
def connectionGuard() {
    return
  long ca = (state.connectingAt ?: 0L) as long
  if (ca > 0L) {
    long age = (now() - ca) / 1000L
    if (age >= CONNECT_STALL_SEC) {
      if (logEnable) log.warn "Connection stalled for ${age}s; forcing reconnect"
      immediateReconnect("connection stalled")
      return
  } else {
    scheduleReconnect("guard not connected")
private void rememberObservedDp(Integer dp, String payload) {
  if (dp == null) return
  def obs = (state.observed ?: []) as List
  def dpLast = (state.dpLast ?: [:]) as Map
  if (!obs.contains(dp)) obs << dp
  obs = obs.collect { it as Integer }.unique().sort()
  if (obs.size() > OBSERVED_MAX_DPS) {
    obs = obs.take(OBSERVED_MAX_DPS)
  dpLast[dp.toString()] = payload
  if (dpLast.size() > OBSERVED_MAX_DPS) {
    def keys = dpLast.keySet().toList().sort().take(OBSERVED_MAX_DPS)
    dpLast = keys.collectEntries { [(it): dpLast[it]] }
  state.observed = obs
  state.dpLast = dpLast
  sendEvent(name: "observedDPs", value: JsonOutput.toJson(obs), isStateChange: true)
  sendEvent(name: "dpLast", value: JsonOutput.toJson(dpLast), isStateChange: true)
private Integer dpFromRelative(String rel) {
  if (!rel) return null
  def m = (rel =~ /^DP(\d+)$/)
  if (m.matches()) return (m[0][1] as Integer)
  m = (rel =~ /^dps\/(\d+)$/)
  return null
private boolean isCommandTopic(String topic) {
  if (!topic) return false
  return topic.endsWith("/${CMD_SEGMENT}") || topic.contains("/${CMD_SEGMENT}/")
private boolean learningEnabled() {
  return enableLearning == null ? false : (enableLearning as Boolean)
private String cleanTopicPart(def v) {
  return (v == null) ? "" : v.toString().trim().replaceAll(/^\/+|\/+$/, "")
private void validatePrefs() {
  if (!brokerHost?.trim()) {
    throw new IllegalArgumentException("MQTT Broker Host is required")
  if (baseTopic != null) {
    def norm = cleanTopicPart(baseTopic)
    if (norm != baseTopic) device.updateSetting("baseTopic", [value: norm, type: "text"])
  if (deviceId != null) {
    def v = deviceId.trim()
    if (v != deviceId) device.updateSetting("deviceId", [value: v, type: "text"])
  if (deviceIp != null) {
    def v = deviceIp.trim()
    if (v != deviceIp) device.updateSetting("deviceIp", [value: v, type: "text"])
private Integer safePort() {
  try {
    def cleaned = (brokerPort?.toString()?.replaceAll("[^0-9]", "") ?: "1883")
    Integer p = cleaned as Integer
    if (p <= 0 || p > 65535) return 1883
    return p
  } catch (ignored) {
    return 1883
private void runInMillisSafe(Integer ms, String handler) {
  try {
    runInMillis(ms, handler)
  } catch (ignored) {
    Integer sec = Math.max(1, (int)Math.ceil((ms ?: 0) / 1000.0))
    runIn(sec, handler)
private String formatEpoch(long epochMs) {
  try {
    return new Date(epochMs).format("yyyy-MM-dd HH:mm:ss", location.timeZone)
  } catch (ignored) {
    return new Date(epochMs).format("yyyy-MM-dd HH:mm:ss")
private static boolean asBool(def v) {
  def s = (v == null ? "" : v.toString().trim().toLowerCase())
  return (s in ["true", "on", "1", "\"true\"", "\"on\"", "\"1\""])
Hope this helps someone out there. Please modify as needed. Don't ask me how this works, it was generated using ChatGPT Codex.
Used ChatGPT Codex to update the code for the Hubitat Driver and fix connection issues.
